ek motor swap
Old Jan 7, 2007 | 11:34 PM
LongJon's Avatar
Default ek motor swap
im thinking about possible motor swaps for an ek im leaning towards a b16a can you guys help me out and tell me what i n eed to do to so the car is ready for a swap, and what i need to upgrade so the motor will function perfect? thanks in advance
Old Jan 8, 2007 | 01:04 AM
mrJDM_DB8's Avatar
diconnect shiftlinkage, remove both axles, disconnect header, un plug entire engineharness, drain the radiator, pull off all coolant hoses, pull a/c and p/s pump, unbolt all 5 motor mounts, and disconnect the clutch line and your ready to pull that motor!
Old Jan 8, 2007 | 01:06 AM
mrJDM_DB8's Avatar
look for an engine that is the same year obd, and you should be able to plug all the factory harness and wire up for vtech. or if it comes with one use it.
Old Jan 8, 2007 | 03:58 PM
LongJon's Avatar
i was looking on a couple of site and it was saying something about i can upgrade to an lsd for like 300 iono can you help m eout wiht that?
Old Jan 8, 2007 | 04:32 PM
MasterKwan's Avatar
Default Re: (LongJon206)
I'd probably do a B18B over a B16A. More torque which you can feel on the street.
Old Jan 8, 2007 | 05:11 PM
Malakai's Avatar
if you got the extra cash, i would get the lsd(limited slip diff). helps for cornering and accel, but u should look into a b18b instead. torque owns.
and down the line you can look into an ls/v. these are my plans
Old Jan 8, 2007 | 05:13 PM
mikeymcm's Avatar
make sure you get the 99-00 si rear bracket also.
Old Jan 9, 2007 | 05:56 PM
LongJon's Avatar
a lot of people say that ls vtec isn't reliable and always breaks down. is that true?yeah the b18b does have more torque but doesnt have v tec and thats why i love haha
Old Jan 9, 2007 | 05:58 PM
LongJon's Avatar
does anyone have info and good combinations of different motors or experiences with different motors? it'll be really helpful in my decision thanks.
Old Jan 9, 2007 | 06:10 PM
Jtuned DC2's Avatar
* B A N N E D *
I dont know dude. it sounds like ls/vtec is a b it outta your league.. but a b16a wouldnt really be that big of an upgrade for that car. If your going to do the swap man think of something other than that. that came in old SiRs and CRXs get a b16b and youll definatly be happy. or an H22 but i think its a bit more work. good luck
Old Jan 9, 2007 | 06:27 PM
LongJon's Avatar
^^ok thanks but i see that the b16b lacks torque so what would be some upgrades that will get the torque numbers up fast?
Old Jan 10, 2007 | 10:10 AM
CBR_15's Avatar
quick question! can you use gsr motor mounts for a b18 swap in an ek?
Old Jan 10, 2007 | 10:16 AM
alacard's Avatar
sounds like you havent looked at this:
https://honda-tech.com/zerothread/878010
Old Jan 11, 2007 | 07:21 PM
LongJon's Avatar
^^that doesnt answer my question
Old Jan 11, 2007 | 07:33 PM
EKHWhat's Avatar
Default Re: (Malakai)
The LSD is really nice to have.
If you want torque, go with a H22.
The only reason I WOULDN'T do a H22 swap is if your car just had to have a/c and power steering. You can fit a/c in there if you try, though.
Its $1,000+ Cheaper than b-series swaps, more torque, and, in some cases, more horsepower.
There are certian things that are different with the H22, but, it's worth it if you ask me.
mostwanted_ek
Southeast
Apr 24, 2018 11:38 AM
morrow921
K Series
Feb 10, 2011 11:42 AM
JDubbs99Civic
Dec 1, 2006 07:52 AM
SF_EF8
Sep 7, 2006 10:15 AM
HOTek9
Mar 22, 2003 10:58 PM
