D16 VTEC head on a D15 VTEC block?
I need to know if there is anything i would need to drill or change to do this to my car would the VTEC work the right way and would it be any faster?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammedcoupe95 »</TD></TR><TR><TD CLASS="quote">I need to know if there is anything i would need to drill or change to do this to my car would the VTEC work the right way and would it be any faster?
there is threads on this all over the place
but answer to your qustion is this
on the non vtec block back there is a plug that plugs an oil port pull it out and thats it
hope this helps
</TD></TR></TABLE>there is threads on this all over the place
hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turb20_vtec »</TD></TR><TR><TD CLASS="quote">Since the d15 is a 1.5 liter, you'll need either a y8 cam gear or adjustable cam gear to adjust your timing since it's going to be off.</TD></TR></TABLE>
y8 adjustable cam gear!
also i keep saying this when ever there is a sohc posting but also would remove middle of head gasket for comp
jdm_titan
Oct 18, 2007 01:38 PM
1991EFBeater
May 13, 2004 07:29 PM
