Idle Problems with 92 integra GSR
Old Jan 7, 2007 | 08:14 PM
DB2NineDuece's Avatar
Default Idle Problems with 92 integra GSR
I just recently purchased a 1992 Acura Integra with a new B16A with everything else orginal 92 GSR.
My problem is that my idle stays at a maximum 800 RPMs at idle when cold. Isn't my idle suppose to be around 1700-1800RPMS? and also when daily driving at then engine warm the car seems to stutter then get back on track like every 10 minutes when driving.
Old Jan 7, 2007 | 10:43 PM
mugenteggy001's Avatar
your idle rpm can differ depending on many different things. There is no set idle area when cold. Now warmed up should be around 500 i think stock. The hesitation or miss could be a number of many things. Plug, wire, gas, iac, timing, etc. Really need more info before we could link the 2 together if they even do link.
Old Jan 11, 2007 | 08:59 AM
98tegLSvtec's Avatar
Default Re: Idle Problems with 92 integra GSR (DB2NineDuece)
WOW thats messed up, my 98 integra ls/vetc right now is idleing wierd! it starts up an automatically goes straight to 3000 rpm's and when it warms up it goes up and down from 3000 rpm's all the way down to 1000rpm's.
Old Jan 11, 2007 | 10:00 AM
95 integra's Avatar
Default Re: Idle Problems with 92 integra GSR (98tegLSvtec)
Normal idle is 750 +/- 50 (so 700-800rpms). Cold idle should be around 1700 and then step down to normal. Probably your IACV.
dc4teg95
Jul 5, 2010 08:09 PM
efyou
Apr 18, 2007 06:00 PM
tigueremalo
Mar 10, 2006 07:49 PM
ashe
Aug 6, 2003 11:18 AM
ashe
Aug 4, 2003 07:39 AM
