HELP!!!!!!!!! H22 civic
Old Jan 7, 2007 | 07:02 PM
H22CIVICJDM's Avatar
Default HELP!!!!!!!!! H22 civic
my civic i jus bought had a h22 swapped in it...the car ran fine i was cleaning it up n all of asudden is boggin now it wont rev past 4 rpm n it shakes alot...is it the ecu? it has a gsr ecu in the meantime i get my h22 could that be it too??
Old Jan 7, 2007 | 07:12 PM
gezzuzz's Avatar
Default Re: HELP!!!!!!!!! H22 civic (dvd_lettermen)
cleaning it up did you wet anything?
Old Jan 7, 2007 | 07:13 PM
Default Re: HELP!!!!!!!!! H22 civic (gezzuzz)
nah like i might have moved the ecu n das about it n hanging wires in the bay but nothing major....
Old Jan 7, 2007 | 07:37 PM
gezzuzz's Avatar
no check engine light?
can you get your hands on a good ecu?
dohc vtec ecu prefer but a p28 will work
Old Jan 7, 2007 | 07:51 PM
it has s gsr ecu in it now...n it was workin fine
Old Jan 8, 2007 | 06:15 AM
gezzuzz's Avatar
check these thing
Map sensor
TPS sensor
ECU..
Old Jan 8, 2007 | 06:53 AM
djsire's Avatar
you prolly wet the diizy
Old Jan 8, 2007 | 08:05 AM
Default Re: HELP!!!!!!!!! H22 civic (djsire)
no water invlove3d is just that it was a swap so it has alot of dangling wires so i just wrapped up n taped some of those wires to make the engine bay look clean
Old Jan 8, 2007 | 08:16 AM
bigl1986's Avatar
with that bogging, it could be the dizzy. try swapping it out with a friends to see if thats the problem. also, check to make sure there is no water in the spark plg chambers. the last thing to check is the ECU. make sure all connectors are correct and find out where those loose wires are from.
Old Jan 8, 2007 | 09:00 AM
Default Re: HELP!!!!!!!!! H22 civic (bigl1986)
das what ima do follow the wires from the ecu and see was up ill get back to you guys on this thanks.....have pictures coming up !!!
mouab18c1
Apr 30, 2009 10:18 AM
mitchtsiawd
Sep 13, 2006 06:52 PM
6GACCORDH22
Feb 1, 2003 10:21 AM
TEK4DR
Dec 2, 2001 11:09 AM
xavier
Dec 2, 2001 10:26 AM
