help with mini me
Old Jan 7, 2007 | 01:37 PM
95droppedhatch's Avatar
Default help with mini me
my motor in my del sol is starting to knock so i went and bought a d15b7 motor and i am going to do a minime i have dont the jdm d15 with the d16 head and i have done the ls/vtec but never the minime so i was wondering if i just bolt the head on the d15 and everything will work the vtec will get the proper amount of oil and everything or do i have to run a line like the ls/vtec setup any help will be appreciated
Old Jan 7, 2007 | 01:44 PM
gezzuzz's Avatar
Default Re: help with mini me (95droppedhatch)
your del sol is a si? just to clear it up you current motor is a d16z6? and you want to put a d15 bottom end on it?
Old Jan 7, 2007 | 01:49 PM
yes it is a si so it has the d16z6 in it i am just going to put the bottom end in in
Old Jan 7, 2007 | 03:03 PM
Richard...'s Avatar
dont you have too remove that oil plug on the block also for the sohc vtec swap
Old Jan 7, 2007 | 03:09 PM
gezzuzz's Avatar
i never heard of ne1 having to feed oil to the vtec on a mini me swap before like the ls.. pull the head off the d15 and see if it has a oil passage to he head..
Old Jan 7, 2007 | 03:11 PM
gezzuzz's Avatar
http://www.jdmuniverse.com/for...32971
thats a whole write up..
Old Jan 7, 2007 | 03:12 PM
Default Re: (gezzuzz)
i have heard the same thing that is why i am asking this before i do it so i dont just put the head on and the v-tec dont get enough oil and i have to pull the head back off
where would the oil passage be on the block of the d15
Old Jan 7, 2007 | 03:22 PM
gezzuzz's Avatar
ok do this.. compare the d16 head gasket to the d15..
if they both have the same holes your are good.
if there is a hole some where on the d16 headgasket thats not on the d15 that might be the oil feed.. make sure there is a hole on the block (you are going to use a d16 head gasket) get it?
Old Jan 7, 2007 | 03:25 PM
schardbody's Avatar
yea i am going to buy a d16 headgasket from honda just so i have no problem with the head gasket but that post you gave me for the swap said nothing about having to drill a hole for a oil feed so it might not but i am not sure i have time to research everything i am not going to pull my motor till next weekend
Old Jan 7, 2007 | 03:26 PM
schardbody's Avatar
Default Re: (95droppedhatch)
here is what you need: https://honda-tech.com/zerosearch
Old Jan 7, 2007 | 03:29 PM
gezzuzz's Avatar
there can;t be to many hole on the head just make sure they line up with a hole on the block..
Old Jan 7, 2007 | 03:33 PM
92hatch_cx-t's Avatar
yeah tyler u just gotta take out a plug on the towards the back/middle of the block. and just bolt on the head. i recomend using the d16y8 head gasket because its metal.
well any other info would be appreciate it and for everybody that has already help appreciate it
Old Jan 7, 2007 | 03:34 PM
schardbody's Avatar
Old Jan 7, 2007 | 03:37 PM
or u can do this. do u still have a 95 hatch?
https://honda-tech.com/zerothread?id=554053
Old Jan 7, 2007 | 03:41 PM
Richard...'s Avatar
Default Re: (sohc dis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc dis &raquo;</TD></TR><TR><TD CLASS="quote">yeah tyler u just gotta take out a plug on the towards the back/middle of the block. and just bolt on the head. i recomend using the d16y8 head gasket because its metal.</TD></TR></TABLE>
thats all you gotta do to make the vtec work
and remove the middle lay of gasket to increase comp!
Old Jan 7, 2007 | 07:56 PM
schardbody's Avatar
dont forget the correct timing belt, timing belt, and adjustable cam gear.
Old Jan 7, 2007 | 08:04 PM
Richard...'s Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">dont forget the correct timing belt, timing belt, and adjustable cam gear.</TD></TR></TABLE>
two timing belts? lol
Old Jan 8, 2007 | 03:06 PM
yea i am putting the ex timing belt and everything from the d16z6
and i dont have my 95 hatch no more i acutally traded it for a 93 si hatch with a built jdm b16 and then sold it and bought a del sol now big mistake i miss my hatch
Old Jan 8, 2007 | 03:31 PM
Syndacate's Avatar
Yeah, just slap the head on.
Make sure you remove the oil plug out of the block, then it'll get the right amount of oil (just wedge a screw driver and it pops right out).
You can wire it up for VTEC directly to the ECU or use an Ex/Si wiring harness.
And you'll be ready to roll, should be pretty straight forward.
Old Jan 8, 2007 | 05:32 PM
ok so i removed the head off the d15 motor and i see the plug in the middle of the block at the back between the number 2 and 3 cyclinder i just remove it and put the head back on and i alreay have everything from the ex because the del sol is a si so it has the d16z6 already in it and i am going to buy the d16y8 headgasket from honda or should i buy the d16z6 headgasket or does it matter
Old Jan 8, 2007 | 05:51 PM
MugenManR's Avatar
this is what you need my friend. your welcome.
https://honda-tech.com/zerothread/554053
Old Jan 8, 2007 | 06:11 PM
appreciate everything any other info would help i will let everybody know how it runs when it is done
U_GOOD
Jul 20, 2009 10:59 PM
civicminded93
Jul 8, 2008 06:21 PM
ToeJam
Dec 29, 2006 05:27 AM
zx2gotboost
12
Feb 1, 2006 10:21 AM
hatch2780
Dec 2, 2005 08:34 AM
