Half my brakes get hot?? turbo civic EK
Old Jan 7, 2007 | 12:16 PM
nfinitecc's Avatar
Default Half my brakes get hot?? turbo civic EK
I have a 99 turbo civic, i was doin my brakes and found my pass front caliper was bad and leaking, after that, when i drive, my driver side front gets HOT! and my passenger side doesnt, like my wheel and lugs would burn your *** on the left side, and i can touch my other rotor, no problem. What could cause this??? i replaced the other caliper, turned my rotors, put new pads and flushed my fluid, im a tech at HONDA so i used all oem parts and fluid, but it has me stumped??
Old Jan 7, 2007 | 12:39 PM
Slamaccord's Avatar
Default Re: Half my brakes get hot?? turbo civic EK (nfinitecc)
Sounds to me like the driver side caliper is sticking.
Unless you didn't bleed the RF and you have air pockets causing the caliper to not
grab a hold of the rotor causing it not to get hot enough. (unlikely)
Old Jan 7, 2007 | 12:56 PM
MasterKwan's Avatar
Default Re: Half my brakes get hot?? turbo civic EK (Slamaccord)
Sometimes the flex-lines collapse internally and cause this too. If you swap the caliper and it still does it, you probably want to replace the rubber line.
Old Jan 7, 2007 | 04:51 PM
hondamark35's Avatar
i bet your caliper slides are sticking. did you grease them when you put the new one on?
and when you flushed the fluid did you bleed the air out of the lines?
also by "tech at honda" do you mean you work at the dealership (just curious)?
CPRracing7
Suspension & Brakes
May 21, 2019 07:10 PM
Misfit2613
Suspension & Brakes
13
May 29, 2015 05:20 PM
Tyson
26
Nov 14, 2007 04:29 PM
square_1
16
May 7, 2007 12:01 AM
Loserkidwac
Jul 31, 2006 07:46 AM
