any way to test out a blue box?
Old May 14, 2002 | 11:49 AM
ceemarun's Avatar
Default any way to test out a blue box?
im buying a used greddy kit, and i was wondering if there is anyway you can test if the blue box works before you install. i'd hate to spend $700 on a turbo install and not be able to drive
Old May 14, 2002 | 01:11 PM
HENRY's Avatar
New User
Default Re: any way to test out a blue box? (ceemarun)
The only way I am aware of to "test" to see if the blue box is working is when it is acutally on the car. Once you get your install done, make sure you're running rich whenever you hit boost and that'll tell you whether or not the blue box is working correctly. If that method doesn't work, you could always go the check valves and Boost dependent FMU route. Lastly, why are you spending $700 on a Greddy kit install. The install is fairly easy and will take about a day or two to do with just basic hand tools. Check out www.turbocivic.net for instructions. With the money you save, you can get a nice intercooler.
Old May 14, 2002 | 01:26 PM
ceemarun's Avatar
Default Re: any way to test out a blue box? (HENRY)
oh, $700 includes the install of a new clutch, an intercooler, timer, boost controller, and some gauges.
Old May 14, 2002 | 02:16 PM
FBP Si 2000's Avatar
There's a green light on the blue box that should be blinking if it's working properly...I know that doesn't answer your question, but whatever.
Old May 14, 2002 | 02:27 PM
SIK IN DA HED's Avatar
New User
Default Re: any way to test out a blue box? (FBP Si 2000)
you shouldve just bought a DRAG kit
ogwutang
Oct 24, 2003 08:15 AM
boostincoupe
Jun 26, 2003 10:10 PM
horror
Oct 15, 2002 04:54 PM
Trac226
May 3, 2002 05:39 PM
