Clutch pedel sticking on 97 gsr??
My Clutch pedel, when i press it down, the clutch engages and everything is fine, but when i let off, it either sticks or comes back up..but some times i gotta pull i tback up with my food, i ended up taking off the the thingy that holds the hydro fluild, and cleaned it out cause it looked dirty and i think i might have had some air in the line, i dunno but how would i go about releasing that and i did refill it, and it hasn't given me any problems yet but i'm just wondering if anything else has had this problem.
Pump the pedal like 10 times, then hold it down, and get someone else to unscrew the bleed screw on the slave cylinder on the tranny real quick and then tighten it back up, before you let go of the pedal. Repeat a few times until straight fluid comes out with no air bubbles at all, and make sure the fluid doesn't go low while doing this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R »</TD></TR><TR><TD CLASS="quote">no reason to change..i like my clutch now, and it supports my all motor..
i'm just wondering why all of a sudden it stuck..</TD></TR></TABLE>
its actually a clutch cylinder not a clutch...so id still invest in the omni power clutch cylinder
93SiHB
Oct 2, 2005 10:00 AM
