CLutch bleeding
Old Aug 23, 2005 | 05:47 PM
TEG777's Avatar
Default CLutch bleeding
i have a 97 TEG, how do i bleed my clutch, can someone give me the steps, THANKS
Old Aug 23, 2005 | 05:50 PM
kapitalc's Avatar
Default Re: CLutch bleeding (boostinteg777)
your gonna need two people. have one person pump the clutch 3 or 4 times, with the final pump hold the clutch to the floor. have the other person open the bleeder valve located on the slave cylinder...when the air bubbles stop comin out close the bleeder valve and once its closed you can let the clutch up. just repeat for a while and you will be fine...remeber to keep an eye on the fluid in the resevoir
Old Aug 23, 2005 | 05:51 PM
TEG777's Avatar
Default Re: CLutch bleeding (kapitalc)
will the clutch come back up by its self
Old Aug 23, 2005 | 05:59 PM
kapitalc's Avatar
when i did mine it didnt i had to lift it up for a while but after a bit of time it was firm when i pumped it
Old Aug 23, 2005 | 06:27 PM
TEG777's Avatar
Default Re: (kapitalc)
did it go up by its self after a while, how many times should i bleed it to get all the air out
Old Aug 24, 2005 | 10:37 AM
TEG777's Avatar
Default Re: (TEG777)
so will it eventually go up by itself
Old Aug 24, 2005 | 11:53 AM
dod's Avatar
dod
once you get hte air to come out it, the pedal will get firmer and come back by its self. i just changed my release cylinder a few days ago and it took about 5 or 6 bleeds to get it back to normal, but i still bled it a few more times to make sure.
Old Aug 24, 2005 | 01:13 PM
temp's Avatar
Default Re: (dod)
if you have ever bled brakes its the same process
Old Aug 24, 2005 | 04:36 PM
TEG777's Avatar
Default Re: (temp)
thanks i will try tommarow
nightscream
Transmission & Drivetrain
Jan 26, 2009 01:45 PM
xunkn0vvnx
Mar 30, 2005 09:23 AM
speedaholic92
24
Sep 8, 2003 04:14 PM
BrandonClaps
Apr 20, 2003 04:43 PM
01PYITR
30
Aug 31, 2002 02:27 PM
