problem with my crx
Old Jan 6, 2007 | 04:05 PM
zccrx's Avatar
Default problem with my crx
ok so it all started with my bad water pump. got to my friends house changed it out no problem. dohc zc by the way. when i put the belt back on i reset timing and cycled the belt around three times. i made sure the lines on the sproketts were right as well as the line and arrow on the bottom was right. when i turn my car on it doesnt want to stay on until it warms up and idle sits at about 1500 rpm. but im throwing a number 9 code. cyl position sensor. could bad timing cause this? or could it be a bad sensor? ps the car ran fine in the morning on the way to my friends house.
Old Jan 6, 2007 | 04:18 PM
zccr-xsi's Avatar
u got to reset your cam gears agaib they aint right.did u make sure the marks on the crank gear and blocked lined up perfect?
Old Jan 6, 2007 | 07:57 PM
h224thgensedan's Avatar
recheck it all make sure that the belt didnt slip off of the crank and move over a bit.
Old Jan 9, 2007 | 07:51 AM
zccrx's Avatar
Default Re: (h224thgensedan)
ok so i reset timing perfectly. the car turns on but it doesnt idle, but when i take off the cold start idle conltrol vaccum line the car idles fine and as soon as i put the line back in he car shuts off. could the idle control bad? i would have to warm up before i can go any where if the cold start is bad and thats gona suck.
Old Jan 9, 2007 | 09:37 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (zccrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccrx &raquo;</TD></TR><TR><TD CLASS="quote"> cold start idle conltrol </TD></TR></TABLE>
Do you mean the EACV? I'm not sure which sensor you're talking about. Can you post a pic of it or describe where it is?
StevenGunn
Nov 21, 2010 03:23 PM
Tarlacon
Nov 9, 2008 10:40 PM
89ludesi
Jun 12, 2007 08:20 AM
Infinity_Racer
Sep 20, 2004 06:02 PM
gsr2jdm
Jan 15, 2004 09:30 AM
