MAP sensor and VTEC.
Old Jan 6, 2007 | 03:22 PM
tksavestheday's Avatar
Default MAP sensor and VTEC.
Hello, I was wondering if CODE 3 (MAP sensor) malfunctioning has anything to do with VTEC not hitting. I have B16a sirII w/GSR trans, JDM P30 in 95 Coupe EX. Any info would be much appreciated. Thank you.
Old Jan 6, 2007 | 04:46 PM
gezzuzz's Avatar
Default Re: MAP sensor and VTEC. (tksavestheday)
map sensor problem im suprized the car is running..
did you just do the swap? or has the code just come up?
did you reset the code to see if it comes back?
did you replace the sensor?
map is what controls your fuel.. IT VERY IMPORTANT!
Old Jan 6, 2007 | 05:49 PM
Default Re: MAP sensor and VTEC. (gezzuzz)
It's been running for awhile actually.. By reset, I turned the car off and turn it back on it goes away for awhile and comes back. I have not replace the sensor yet.. working on it though. MAP controls the fuel? would that be the reason why I get really shitty MPG? I'm getting like 54 miles on 2.8~3 gal.
Old Jan 8, 2007 | 11:33 PM
squarepusher's Avatar
im having similar problem.
i have h22 in a 96 civic ... i get CEL code 3...
to reset the code, you need to remove the Radio fuse for 30 seconds, then replace.
i get MAP sensor error, and my car runs really bad (LIMP Mode).
I ordered a new map sensor off eBay, that was tested working (I believe them), and when I installed it I get the SAME error as before!!
I checked the ECU wiring, and its all legit. So im just really confused now on what to do ...
suggestions?
I think all likelihood points to my MAP sensor working fine ... maybe i have a similar error to the OP ...
Old Jan 8, 2007 | 11:36 PM
gezzuzz's Avatar
Default Re: MAP sensor and VTEC. (squarepusher)
is your map sensor the kind on the throttle body?
Old Jan 8, 2007 | 11:39 PM
well, since its a Prelude MAP sensor for an H22 ... normally the Prelude MAP sensor is on the firewall ...
but on the civic its on the throttle body, and I think its the same for an Integra (OP's car)
Old Jan 8, 2007 | 11:43 PM
gezzuzz's Avatar
take the map sensor out and clean in that hole it can be cloged
Old Jan 8, 2007 | 11:44 PM
i see, thank you, i will try this ...
but i do have 2 map sensors giving the same error ... maybe the tube is clogged? hmm
well, from reading somewhere else, i don't have a CAT installed on the car ... yet that is ... do you think THAT could be causing the CODE 3 map SENSOR error?
Old Jan 8, 2007 | 11:48 PM
gezzuzz's Avatar
you obd-1 or 2
Old Jan 8, 2007 | 11:51 PM
Default Re: (gezzuzz)
conversion 2 -> 1 (1996 civic to 1995 H22 prelude engine)
I quadruple checked the wiring on the conversion, and it seems to be just as the guides say D3 and D4 going to D17 and D19 on the conversion wiring.
Old Jan 8, 2007 | 11:56 PM
gezzuzz's Avatar
Default Re: (squarepusher)
was the motor running fine after the swap? or did it never run right?
Old Jan 9, 2007 | 12:06 AM
it was running OK for a while with no CEL ... then coming back from on a trip ... it threw the CEL on the way back ....
I think I need to analyze the OBD advanced codes if i can ...
I know how to jump and get the simple codes ... but not sure hwo to get the advanced codes ... which i think can help me .. like
"P0106 Manifold Absolute Pressure (MAP) Sensor Range/Performance Problem"
im not sure hwo to get those too . or if i can
Old Jan 9, 2007 | 12:13 AM
gezzuzz's Avatar
thats obd-2 code.. obd-1 is just simple code.. thats y we convert to obd-1..
do you have a honda work shop manual?
Old Jan 9, 2007 | 12:15 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gezzuzz &raquo;</TD></TR><TR><TD CLASS="quote">thats obd-2 code.. obd-1 is just simple code.. thats y we convert to obd-1..
do you have a honda work shop manual? </TD></TR></TABLE>
unfortunately not ... ut i do have a voltage meter ... do you suggest that I start checking individual volts for each wire relating to the MAP sensor on teh ECU (or at the MAP sensor in the engine itself?)
Old Jan 9, 2007 | 12:16 AM
gezzuzz's Avatar
go to http://www.hondahookup.com/manuals/ and download Honda Civic 92-95 Service Manual (Bookmarked) (84Mb PDF)
im going to find the page for the map sensor
you going to need a download manager to download it (site acts gay(
http://www.freedownloadmanager.org/download.htm
Old Jan 9, 2007 | 01:39 PM
all right!! thanks a lot gezzuzz!!
Are you sure i should download the 92-95 civic manualk, if i am running a 95 Prelude engine (h22) in a 1996 civic?
i am downloading currently, its a big file =] i appreciate the help truly
Old Jan 10, 2007 | 08:43 PM
bump with update.
as per this post
https://honda-tech.com/zero...46478
Here is the flow chart I got from the Honda Manual, and also what results I got so far ...
now, on the final step, I get 4.74V, when I should get 5V. This I think is a problem ... however I have 2 ECU's here, P13, and P28 ... and I get CEL on both ...
so both ECU's give the same ... so Ithink i am goign to have to do some more thinking on thsi one ...
92SikHatchBak
Engine Management and Tuning
Jan 6, 2010 09:38 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
92ehatch
16
Feb 19, 2007 11:41 PM
Sci_v_icI
Apr 5, 2006 10:44 AM
slowazzhatch
Jun 1, 2003 07:42 PM
