Windows, locks, and el gauges won't work, help!
Old Jan 6, 2007 | 12:48 PM
clemsoncb7's Avatar
Default Windows, locks, and el gauges won't work, help!
Hey all,
As many of you may know, I have a 4th gen lude and I was having it tuned and all of the sudden the gauges wouldn't turn on, the windows and sunroof wouldn't roll up or down, and the locks were malfunctioning. The only thing electronically that was altered while we were tuning was the wiring of the map sensor which I had messed up.... Otherwise, all fuses are good and all that lights up on the dash is a battery light, which is strange.
Also, headlights and center console (cig. lighter and cd player) all function...
These problems to me don't seem linked but they all happened at once, any opinions? If you have any questions for me just let me know. Thanks in advance guys...
Max
Old Jan 6, 2007 | 09:09 PM
clemsoncb7's Avatar
Default Re: Windows, locks, and el gauges won't work, help! (maxvtec7500)
Bump
Old Jan 8, 2007 | 11:20 AM
clemsoncb7's Avatar
Does anyone think this could be the dimmer switch? Thats what I've been lead to however I don't know where its located or anything so any help would be appreciated. I also read something about a multiplex unit, however I don't know what that is or does or where its located..... Any help would be appreciated!
Thanks
Max
Old Jan 8, 2007 | 11:25 AM
Hawkze_2.3's Avatar
No fuses are blown?
Old Jan 8, 2007 | 01:55 PM
clemsoncb7's Avatar
Default Re: Windows, locks, and el gauges won't work, help! (Hawkze_2.3)
Nope, all fuses checked out alright, I also read about a meter fuse, is that on the main fuse blocks? (interior and engine)
Max
Old Jan 8, 2007 | 02:57 PM
handicapable's Avatar
did you try disconnecting and then reconnecting the battery?
Old Jan 8, 2007 | 05:31 PM
clemsoncb7's Avatar
Default Re: Windows, locks, and el gauges won't work, help! (handicapable)
No I actually haven't, I wouldn't think it would do anything, but I guess its worth a try....
Max
Old Jan 9, 2007 | 08:10 AM
clemsoncb7's Avatar
Bump for more suggestions/answers....
Old Jan 9, 2007 | 08:58 AM
Hawkze_2.3's Avatar
I wish there was a simple thing to check that I could think of, but now it looks like you'll probably just have to get a factory service manual and go through the wiring diagrams...
Old Jan 9, 2007 | 12:36 PM
clemsoncb7's Avatar
I have the factory service manual and going through the wiring diagrams just isn't helping me, I'm not sure where to look for it....
Max
Old Jan 9, 2007 | 03:14 PM
PrettyLude's Avatar
i might be mistaken but the 4th gens don't have the multiplex system in it.
Old Jan 9, 2007 | 03:35 PM
clemsoncb7's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">i might be mistaken but the 4th gens don't have the multiplex system in it.</TD></TR></TABLE>
I couldn't tell you, all I know is that it was mentioned and I'm still fuzzy as to what it actually does....
Max
Old Jan 9, 2007 | 09:23 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">I have the factory service manual and going through the wiring diagrams just isn't helping me, I'm not sure where to look for it....
Max</TD></TR></TABLE>
Start with one of the things that isn't working and test all the wires going into it (some are power, some are ground, some only have power when a switch is on, etc). When you find a wire that's not getting what it should, then use the diagrams to find out where it goes to and check the next thing in line...eventually you'll find the problem.
Old Jan 10, 2007 | 02:35 PM
clemsoncb7's Avatar
Okay well just an update for anyone who is interested or who can help me out further. Anthony tried the dimmer switch, relay, and fuses, nothing still.... Very frustrating! Thanks thus far guys but any more help is greatly appreciated!
Max
FMN716
Dec 11, 2014 08:24 AM
photec2
Jan 14, 2010 01:57 PM
davidluko
Apr 9, 2006 12:37 AM
Fly1865
Jun 17, 2004 01:00 PM
