What kind of signal is a tach signal?
Old Jan 6, 2007 | 06:27 AM
fmfkid250's Avatar
Default What kind of signal is a tach signal?
what is it like pulse per min?
and what the difference between. 4,6,8 cyl?
this is sord of a dumb question but i cant find it anywhere
Old Jan 6, 2007 | 06:31 AM
tony1's Avatar
Default Re: What kind of signal is a tach signal? (fmfkid250)
it's a 12v square wave signal.
Old Jan 6, 2007 | 07:38 AM
RC000E's Avatar
Default Re: What kind of signal is a tach signal? (tony1)
Yeah, the if you view the ignitor triggering the primary coil on a scope with the on/off, on/off that is what basically creates your tach signal. That's why the tach jumping around is an immediate indicator of an ignitor problem.
Old Jan 6, 2007 | 08:02 AM
Flexmyrex's Avatar
the only difference between 4,6,8 is the way the tachometer is calibrated to convert the number of reference pulses into engine speed using rpm display on the tachometer. It takes 2 crankshaft revolutions to fire all the cylinders once. On a 4 cylinder, that would mean 4 pulses is 2 rpm. At idle speed if the tach is recieving 1600 ref pulses pm it converts it to 800rpm. Now On a 6 cylinder 1600 ref pulses pm would mean about 530RPM.... you get the point.
Old Jan 6, 2007 | 01:12 PM
fmfkid250's Avatar
Default Re: What kind of signal is a tach signal? (Flexmyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexmyrex &raquo;</TD></TR><TR><TD CLASS="quote">the only difference between 4,6,8 is the way the tachometer is calibrated to convert the number of reference pulses into engine speed using rpm display on the tachometer. It takes 2 crankshaft revolutions to fire all the cylinders once. On a 4 cylinder, that would mean 4 pulses is 2 rpm. At idle speed if the tach is recieving 1600 ref pulses pm it converts it to 800rpm. Now On a 6 cylinder 1600 ref pulses pm would mean about 530RPM.... you get the point.
thats what i was looking for, thanks alot!!!
Steve-T
Aug 14, 2017 04:36 PM
lexusgui
Jul 27, 2008 07:54 PM
A.D.D. Racer
May 24, 2006 09:02 AM
Average Al
Jan 22, 2004 04:13 PM
SleepnCiViC
14
Jan 16, 2004 05:46 PM
