Fidanza Flywheel ??
Old Jan 6, 2007 | 03:51 AM
lude98SH's Avatar
Default Fidanza Flywheel ??
I havent heard anything bad about the quality of fidanza lightweight aluminum flywheels but i was on preludepower and under the parts list it says its not recomended. Why is this ?
http://www.preludepower.com/fo...13216
Old Jan 6, 2007 | 04:11 AM
hu's Avatar
hu
Default Re: Fidanza Flywheel ?? (lude98SH)
The only reason I can think of beside that it is a idiotic site is that it might be "eaten" up easy. Hope that makes sense.
I personally prefer the cromoly flywheel (8.8lbs) compared to the fidanza which is 8lbs becasue it is stronger.
IMO, it seems like every Lude owner has a Fidanza flwheel!
Fidanza is an excellent flywheel...
Old Jan 6, 2007 | 04:45 AM
prelude2perfect's Avatar
Default Re: Fidanza Flywheel ?? (hu)
werd, I love my fidanza
Old Jan 6, 2007 | 06:35 AM
mgags7's Avatar
Default Re: Fidanza Flywheel ?? (prelude2perfect)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude2perfect &raquo;</TD></TR><TR><TD CLASS="quote">werd, I love my fidanza</TD></TR></TABLE>
I've been driving on it for 30k and couldn't be happier
Old Jan 6, 2007 | 12:06 PM
russlan44's Avatar
Default Re: Fidanza Flywheel ?? (bb4ever)
before i put this down and u guys correct me if im wrong but does findaza flywheel has a mark? so u can check the timing or is it has to be the correct way to put it on or just slam it and screw it in??
Old Jan 6, 2007 | 12:09 PM
vlude99's Avatar
there is a little hole in on the flywheel that fits perfectly on the dowel pin that come from your engine bay. that makes sure your timing is correct. The problem i ran into as i was installing the fidanza was that the hole was slightly too small so i had to dremel the hole to make it bigger. after that...no problems whatsoever. i love the fly
Old Jan 6, 2007 | 12:57 PM
117's Avatar
117
I've only seen one problem with a Fidanza where the flywheel bolts back out, but more than likely that was due to installer error.
I prefer a chromoly flywheel myself, but I've used the Fidanza with no problems and the other track 5gen I work on uses a Fidanza with no issues.
Old Jan 6, 2007 | 02:29 PM
tmrtwo's Avatar
Default Re: (vlude99)
i ran into the exact same problem.....bringin it to work monday and reeming out the holes in the drill press
2kdrift
Oct 13, 2007 06:29 AM
Boostage
Jul 5, 2007 03:01 PM
mrx
Oct 1, 2004 11:17 AM
ProjectLudeSiR
Mar 15, 2004 03:21 AM
yellowbuffalo
Jun 20, 2003 04:45 PM
