Slotted brakes
Old May 14, 2002 | 09:01 AM
stspj's Avatar
Default Slotted brakes
I got my pics of my brake install its not a big brake kit but its better than stock.
Old May 14, 2002 | 09:10 AM
94CivicSi's Avatar
Default Re: Slotted brakes (stspj)
brake upgrades
orange calipers
What kind of pads did you go with?
Old May 14, 2002 | 09:30 AM
Dodger2940's Avatar
Default Re: Slotted brakes (94CivicSi)
What kit is that and where you get it from?
Old May 14, 2002 | 09:33 AM
SpoolinEK's Avatar
i believe those are red calipers..
Old May 14, 2002 | 09:54 AM
Sohc Driver's Avatar
Default Re: Slotted brakes (EG Civic)
I heard slotted and drilled rotors can warp...any info on this issue?
Khoi
GokuSSJ4's Avatar
what pads are you running ?
Old May 14, 2002 | 10:05 AM
Troy's Avatar
Default Re: Slotted brakes (Sohc Driver)
cross drilled rotors will crack, slotted rotors are fine
Old May 14, 2002 | 10:07 AM
stspj's Avatar
Yes there red. The kit was from landspeed racing it was the sport kit ( 2 rotors, and pads). The racing kit has 4 rotors, pads, and stainless steel brake lines. Sport kit was 200 and the race kit was like 425. Powerstop powerslot rotors and pbr pads. I checked on the warping issue. The slotted and drilled rotors can warp more easily because of the lower amount of actual metal in the rotor. Although you can warp any rotor if you really try.
[Modified by stspj, 7:08 PM 5/14/2002]
Old May 14, 2002 | 10:38 AM
Driven's Avatar
what prompted you to get this "kit"? I mean, outside of the better pads, you won't really see an improvement in braking distances...
You could have just as easily bought some Hawk HP Plus brake pads, turned the rotors and had great braking? Just curious on the decision.
Old May 14, 2002 | 11:46 AM
todaCspec's Avatar
Default Re: Slotted brakes (Driven)
look in summit ad,says cross-drilled stay 200 degrees cooler than stock rotor.also lighter weight and resists warping 3x's than stock.
Old May 14, 2002 | 12:49 PM
stocker's Avatar
Default Re: Slotted brakes (geechieracer)
I think summit is just trying to sell their products.
Old May 14, 2002 | 12:50 PM
Grimm's Avatar
yea summit is trying to sell you the rotors they aren't gonna say that the warp quicker and crack easier?
IMO i'd stay away from the cross drilled not needed at the speeds your going to be going... especially with the pads your runnin'. As far as slotted...eh
the better the caliper / pad the better the braking the lines make a significant difference if you go that far.
Old May 14, 2002 | 09:12 PM
.paul's Avatar
Default Re: Slotted brakes (Grimm)
i doubt you'd go that fast to need slotted.. it's rare that any street car would.. but i got htem on my car.. i jsut like the way they look ;p
tacosandbeans
Dec 6, 2010 07:02 PM
UnoPuntoCinco
May 30, 2007 04:23 PM
anhthanh
Apr 7, 2007 05:20 PM
clin20
Jun 7, 2004 08:30 AM
FK00GSR
Oct 30, 2002 08:20 PM
