in need of info quick
hi guys the r that i picked up (salavge, see my other post) is missing the stick in the rear quarter that says: mfd in japan by honda motor co. I need to know the exact weight of the type r: gvwr gawr f r I need this info for customs asap thanks!
nope, i need the 3 different weights entered there all 3 are in lbs, thanks tho! i needed the mfg date, got it thru acura but they coulnt tell me the weights
i know thats whats written all over the net, but on the sticker in the car, its higher than that for sure dont know why.... what im looking for is: gvwr= witch i the total gros vehicule weight then the gawr f=gross vehicule weight in the front then the r= same thing but the back, thats how its written on the sticker. That would be perfect, as i need this info in 1:30 tops lol
Modified by boostedr at 11:43 PM 1/5/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedr »</TD></TR><TR><TD CLASS="quote">i know thats whats written all over the net, but on the sticker in the car, its higher than that for sure dont know why.... what im looking for is: gvwr= witch i the total gros vehicule weight then the gawr f=gross vehicule weight in the front then the r= same thing but the back, thats how its written on the sticker. That would be perfect, as i need this info in 1:30 tops lol</TD></TR></TABLE>
dont get pushy or Ill post the wrong weights
I dont remember ever noticing the weights broken down to front to back like that...but Ill check
as i thought, my car has nothing like you are describing. the only stick remotely close to what you are talking about is all tire/seating information.
700lb weight capacity
pressures F 35 R 33
size 195/55/R15 84V
seating 4 total 2 front 2 rear
pressures F 35 R 33
size 195/55/R15 84V
yes there has to be, somebody answered me on itrca, look at the pic, this is what i was looking for! thanks!
http://www.itrca.com/forums/viewtopic.php?t=7889
Modified by boostedr at 12:17 AM 1/6/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedr »</TD></TR><TR><TD CLASS="quote">thanks, also is your car a 98 to 01? because if its a 97 the wights will be lower, mine is a 00, thanks again, greatly appreciated
Actually 97 is little heavier: Curb Weight: 2643 lbs.
2000 Type R: Curb Weight: 2643 lbs.
I got that info from edmunds.com.
</TD></TR></TABLE>Actually 97 is little heavier: Curb Weight: 2643 lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00TypeR1071 »</TD></TR><TR><TD CLASS="quote">
Car and Driver had the '97's curb weight as 2560 lbs.
I'd expect this number to be more accurate, as the '00 was 2639 lbs, and featured standard A/C and rear wiper.
Except he wasn't looking for curb weight.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedr »</TD></TR><TR><TD CLASS="quote">yes there has to be, somebody answered me on itrca, look at the pic, this is what i was looking for! thanks!
Modified by boostedr at 12:17 AM 1/6/2007</TD></TR></TABLE>
oh that sticker
oh that sticker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 330R »</TD></TR><TR><TD CLASS="quote">Car and Driver had the '97's curb weight as 2560 lbs.
I'd expect this number to be more accurate, as the '00 was 2639 lbs, and featured standard A/C and rear wiper. </TD></TR></TABLE>
The curb weight all depends on if the car tested had a factory installed air conditioning or not. Hence why you usually see two weights, one in the mid 2500's and the other about 60lbs more.
To the OP, letting us know what year ITR you need the info from will help with your search.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">The curb weight all depends on if the car tested had a factory installed air conditioning or not. Hence why you usually see two weights, one in the mid 2500's and the other about 60lbs more.</TD></TR></TABLE>
Isn't that what I said?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">To the OP, letting us know what year ITR you need the info from will help with your search.</TD></TR></TABLE>
I might be wrong, but the GVWR is probably the same across the model years.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">lol probably, working on 3hrs sleep</TD></TR></TABLE>
I hear ya.
TGIF
I hear ya.
TGIF
wjcsmithinc
Apr 4, 2004 06:51 PM
