Need help.......
Old Apr 29, 2009 | 03:36 PM
UCI_Type-R's Avatar
Icon2 Need help.......
Im rebuilding my 00 B18C5, and i need to buy new crankshaft mains. So i went into the Delray Acura website and it gave me seven choices for the top mains and ten for the bottom ones. Well, i know that it only uses 5 but what is the difference between the colors it shows and TAIHO and DAIDO in the parenthesis.....Really needs info on this....which should i order need them ASAP.
heres the link to the delray site. It is illustration #12 and 13.
http://www.acuraoemparts.com/delray/...All&vinsrch=no
THANX in advance for the input.
Old Apr 30, 2009 | 06:19 AM
Dave-ROR's Avatar
Default Re: Need help.......
Manufacturer.
Edit: oh, and the colors, different thickness of bearings, you need to plastigage/measure clearances. Are you sure you know enough about this for the job? (no offense intended)
Old May 1, 2009 | 11:56 AM
UCI_Type-R's Avatar
i dont really know much bout this mechanic does though....but he just asked me to order these mains and when i saw the colors i did not know which is the one that comes stock.....so in this case what color should i go for, for the bottom and the top? I just want it back to stock mode.
Old May 1, 2009 | 12:18 PM
nightrider93ex's Avatar
Default Crank Bore Code Location.
Letters have been stamped on the end of the block as a code for the size of each of the 5 main journals bores. use them, and the numbers stamped on the crank (codes for main journal size), to choose the correct bearings.
Old May 1, 2009 | 01:56 PM
irev210's Avatar
yes, there are grids in the helms manual that will tell you what color bearing to buy for the block letter/crank number
Your mechanic shouldn't be rebuilding this if he is not experienced with hondas
Old May 1, 2009 | 02:58 PM
UCI_Type-R's Avatar
well i called a Acura dealership and they told me that each bearing has the color printed on the side of the bearing.....so i went got the bearings and sure enough they did....u learn something everyday.....Thanks to Hector at Gunn Acura in San Antonio Texas.( great service)
JaviBx
Mar 30, 2011 06:01 PM
vaporboy12
May 6, 2006 08:42 AM
low_crx87
Aug 31, 2005 10:27 PM
jdmotorsports
Aug 29, 2005 12:33 PM
