91 CRX with D16: Which motor mounts to use?
Old Jan 5, 2007 | 08:23 AM
mjfx's Avatar
Default 91 CRX with D16: Which motor mounts to use?
My mounts are going really bad. I have a d16 engine with a si tranny in my 91 crx. Which mounts should I buy? And can I install them myself? thanks!
Old Jan 5, 2007 | 08:27 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: 91 CRX with D16: Which motor mounts to use? (mjfx)
Well honestly, use stock unless you want to upgrade the inserts but depending what you are doing with the car it might not be worthwhile.
Old Jan 5, 2007 | 08:53 AM
crxnj's Avatar
these are nice http://cgi.ebay.com/ebaymotors...QrdZ1 ive installed them before
if you have automotive knowledge and the right tools,yes,you can install them yourself..its not really hard its just the space.
Old Jan 5, 2007 | 11:28 AM
STREETWERKZ's Avatar
Default Re: 91 CRX with D16: Which motor mounts to use? (mr.speaker)
i thought my mounts were sloppy....
so i bought inserts and brand new OEM mounts. the mounts were sloppy because they were old and warn. the new mounts alone made the car feel a lot better. when i installed the inserts, it was just a bonus. but probably not needed.
Old Jan 5, 2007 | 12:13 PM
mjfx's Avatar
thanks for the responses!
I was mostly wondering if I needed a different mount than stock since the engine is from a 96 civic. But I guess they use the same mounting points.
I am pretty good with tools.
But do I have to move the engine in any weird way? Or just kinda shove it a lil?
Theyre kinda blown so I think Im gonna replace the mounts and the inserts. If theres a write-up anywhere I'd appreciate the link! thanks again!
Old Jan 5, 2007 | 07:13 PM
mjfx's Avatar
can anyone help me out?
Old Jan 5, 2007 | 09:29 PM
mjfx's Avatar
k I'll paypal $2 to whoever can get me some good info.
sheesh..
Old Jan 5, 2007 | 10:09 PM
RockWolf's Avatar
Default Re: (mjfx)
ok maybe its not some good info but a bump in the same time....
well if i recall well the placements and all the mounts positions. you would need to unmount and use engine lif or what ever to get the engine high about couple of inchs..then you change all of them in the same time. but you cant lift too much or you will pop out the axles... I dont know if this can be done...other wise drain you transmission liquide and pop the axle to lift the engine.
Srry if it unaccurate information just trying to help a fellow member ^^.
Old Jan 6, 2007 | 07:50 AM
mjfx's Avatar
Default Re: (RockWolf)
I guess it may be best to take it to a shop then. I'll probably order those mounts from ebay too. thanks for all your help!
clem kevin
May 1, 2008 06:57 PM
CeeAreEx90
15
Jan 7, 2005 03:55 PM
ComputerJLT
Jul 2, 2004 02:25 PM
Tire Monkey
May 2, 2004 05:23 PM
whoobeedoobee
Jun 15, 2003 04:35 PM
