Honda S2000 Honda S2000
S2k using oil?
Old Jan 5, 2007 | 06:57 AM
Norwegian's Avatar
Default S2k using oil?
Did a search, but didn't find anything..
I filled my S2k up with oil about a week ago. let the engine cool down for half an hour, then filled it up to the "H" mark.
Today, I checked the oil again, and the oil level has gone down two marks on one side of the measuring pin, but on the other side of it the oil level seems fine? This time the car was cold, been sitting in the garage since yesterday. Car has done aprox 50000 miles
Help?
Old Jan 5, 2007 | 07:10 AM
s2kdre's Avatar
Default Re: S2k using oil? (Norwegian)
what year is ur s2k? if its the older one, then they all burn a little oil, change the oil and recheck it after 1000 miles to see how much it burns.
Old Jan 5, 2007 | 07:11 AM
s2kdre's Avatar
Default Re: S2k using oil? (s2kdre)
my 04 will burn about a quart every 5,000 miles.
Old Jan 5, 2007 | 03:26 PM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre &raquo;</TD></TR><TR><TD CLASS="quote">my 04 will burn about a quart every 5,000 miles.</TD></TR></TABLE>
My 05 doesn't burn any... not even half a hash mark. Might wanna check it out.
Old Jan 5, 2007 | 04:27 PM
negcamber's Avatar
Not uncommon. Some use more than others, but early cars frequently use more than later years. Part of the F20/22 engine design is to squirt oil on the cylinder walls, which leads to more oil use than other engines.
Old Jan 6, 2007 | 08:22 AM
Rtzx9r's Avatar
GDD 1%
Properly checking oil level is done when the car is hot, just after you turn it off.
Checking it a half hour later, or when the car is cold, will not give proper levels.
Old Jan 6, 2007 | 08:35 AM
Norwegian's Avatar
Default Re: S2k using oil? (Rtzx9r)
Seriously?
Is this just for the s2000? I've always heard that the car should cool down for a bit first...
Edit: It's a 2000 model
Old Jan 6, 2007 | 09:46 PM
austincrx's Avatar
Actually, to get the 'proper' reading for oil level, wait a little while after the car is run, ten minutes or longer should be enough, unless you're at a track day, then wait longer, the oil will expand a great deal (the level rises a quart in my race car when I am racing). If you don't wait, the oil will still be draining from the head and still be hot, therefore expanded, it doesnt take long for the oil to drain out of the head, but it's always best to check it in the mornings, before you drive it, when it's ice cold the actual level is more accurate then.
Old Jan 7, 2007 | 06:11 AM
efstile's Avatar
i have an 03 and it burns absolutely no oil at all. my uncle has the same car and his doesnt either. Maybe just be a little easier on it? i aint no old lady but i understand you cant beat on something constantly and have it run forever. shocking, i know.
Old Jan 7, 2007 | 10:22 AM
* B A N N E D *
Default Re: S2k using oil? (efstile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efstile &raquo;</TD></TR><TR><TD CLASS="quote">i have an 03 and it burns absolutely no oil at all. my uncle has the same car and his doesnt either. Maybe just be a little easier on it? i aint no old lady but i understand you cant beat on something constantly and have it run forever. shocking, i know.</TD></TR></TABLE>
I beat on mine repeatedly and it burns no oil. It depends on how you break in your motor.
Old Jan 7, 2007 | 02:27 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: S2k using oil? (Mr. Projekt)
My year 2000 burns about 1/4 quart per oil change interval. So it burns a negligible amount of oil...even after a 2 day road america abuse fest last fall.
. But its pretty common for high revving motors (especially honda) to consume oil. The piston squirters probably do cause more oil consumption than usual motors, though. My SR20DET used to burn about the same amount....as well as my B16 (although i dont know if the oil squirters were only reserved for B18s in the B series family). I think i've just been lucky with typically high oil consumption motors that burn no oil in my hands even if i beat on the car a lot. I guess God must like me
HYREV2NR
Honda Fit
80
Oct 6, 2008 02:00 PM
riceball777
Honda S2000
Aug 28, 2008 08:28 AM
d3xt3r19
Honda Civic (2006 - 2015)
Dec 5, 2007 05:30 PM
coupon
Aug 28, 2005 12:19 PM
andyep3
Apr 20, 2005 06:53 AM
