omg. im an idiot.
ok so today i had quite a few projects on the whip... i got my rear under tie bar. (installed) . new thermostat to fix overheating problem hopefully... ( installed ) . Now... i was putting on the rear upper strut bar... and one of the bolts was a tiny bit stripped. im guessing the leshwab guy did it when he lowered it. well... i made it REALLY bad. almost a circle. how in the hell do i get it off..? and yes i used wd40. and lockease.
If you have a angle head grinder... you could use that and then replace the nut when you get it off...
Either that or a socket designed for stuff like that.
Needs to be About 20% Cooler
i would try locking pliers or u could allways dremel the nut off.
the dremel is one of those tools u never use but when u need it it's the best tool u'll ever have
I know there's not alot of room back there but these would work. http://www.sears.com/sr/javasr...e=Yes I've used them on 2 stripped nuts and they've worked like a charm.
effin
Apr 28, 2011 06:52 AM
97hatchblack
34
May 29, 2004 07:00 AM
