wont go into gear
i have a b16 in my eg i hvent dirivin the car in a month or so one day i went to move it and i couldnt get it in gear i changed out the slave cylinder is there any way for me to be sure what the problem is when the car is off it goes right in ????? thanx
same problem and also my clutch pedal would get stuck down while driving. well my problem was that the pedal coming up too far in you look under to the pedal you will see that there's a screw that limits the pedals distance from coming up. the bolt should be all the the way screwed. hope that this helps Good luck
