Rebuilding on a budget
Old Jan 4, 2007 | 03:50 PM
SiTR's Avatar
Default Rebuilding on a budget
Well im about to rebuild my block and was wondering if i should raise the compression to 11.5:1 or raise it to 12:1 and have to spend aliitle extra on injectors and a fuel pump? I'm going to use my stock head since i'm on a budget so what i was wondering was if its worth it to go with the 12:1 and spend a little extra cash or just stick to the 11.5:1?
Old Jan 4, 2007 | 03:58 PM
doood's Avatar
been there done that
Default Re: Rebuilding on a budget (SiTR)
a list of your current mods and power goals would be really helpful...
Old Jan 4, 2007 | 04:00 PM
zc911's Avatar
if your on a budget, JDM ITR pistons and thin headgasket
Old Jan 4, 2007 | 04:03 PM
PrinceAli132's Avatar
Will you be using 91 or 93 octane?
How do you plan on raising the compression; pistons, headgasket, valves?
Ali
Old Jan 4, 2007 | 04:15 PM
SiTR's Avatar
I was going to raise it with the pistons. my budgets is $1400.00. As for my mods all i have is an iceman short ram. jdm 4-1 header, complete msd set up distibuter and all, exedy stage 2 clutch, and a jasma exhaust. Don't think that it matters but it's in a 99 si.
Old Jan 4, 2007 | 04:34 PM
Stinkycheezmonky's Avatar
Suspetise...
Default Re: (SiTR)
Jasma exhaust, eh? Right. Anyway, JDM ITR pistons are your best bet. 12:1 with stock cams and all is kind of silly.
Old Jan 4, 2007 | 04:41 PM
SiTR's Avatar
jasma muffler. i forgot i have ctr cams in it. i also have a set of stage 2 crane cams i can throw in if needed.
doood's Avatar
Default Re: (SiTR)
jasma doesnt make parts. just so you know.
Old Jan 4, 2007 | 04:45 PM
Suspetise...
Default Re: (SiTR)
You'll also want to keep tuning in mind, as that would be a good idea as well.
Old Jan 4, 2007 | 04:52 PM
Doostur's Avatar
Hehe... another one.. bradstard is in the same boat... itr on a budget.
Old Jan 4, 2007 | 04:56 PM
SiTR's Avatar
Default Re: (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">jasma doesnt make parts. just so you know. </TD></TR></TABLE>
Oh....... well it has jasma imprinted on it.
So 11.5:1?
Old Jan 4, 2007 | 06:21 PM
Splat's Avatar
Collector-o-Guns and Drinker
"Budget" and "high compression" don't really belong together.
Old Jan 4, 2007 | 09:10 PM
Suspetise...
Default Re: (SiTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiTR &raquo;</TD></TR><TR><TD CLASS="quote">So 11.5:1?</TD></TR></TABLE>
Whatever the JDM ITR pistons give you. That's a slight bump from stock, will feel good, and won't blow up on you.
Old Jan 4, 2007 | 09:35 PM
actionanh's Avatar
Default Re: Rebuilding on a budget (PrinceAli132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrinceAli132 &raquo;</TD></TR><TR><TD CLASS="quote">Will you be using 91 or 93 octane?
Ali</TD></TR></TABLE>
I wish we had 93 octane in my area!
Old Jan 5, 2007 | 03:05 AM
jdm_DC2R's Avatar
You can try to trade in your msd setup, and get soemthin that gives u some power in return, there is nothing wrong with the factory distributor as i believe its good up to 600whp or some figure like that. So you can spend that money somewhere else more wisely.
Old Jan 5, 2007 | 09:14 AM
SiTR's Avatar
Default Re: (jdm_DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">You can try to trade in your msd setup, and get soemthin that gives u some power in return, there is nothing wrong with the factory distributor as i believe its good up to 600whp or some figure like that. So you can spend that money somewhere else more wisely.</TD></TR></TABLE>
yeah iv'e been told this several of times i guess i'll do that. My motor is a 97 so stock compression was already 11:1 since its jdm. So then i should just stick with going to 11.5:1 then? I really wanted to go boost but im not going to have cash for that right now so. I'm just trying to get the most out of it and not come back out slower by lowering the compression for boost and waiting till i get cash to actually go boost.
Old Jan 5, 2007 | 12:27 PM
doood's Avatar
Default Re: (SiTR)
if you're compression is already 11:1 just throw in some bigger cams.
Old Jan 5, 2007 | 01:15 PM
SiTR's Avatar
but if im rebuilding it i really didn't want to rebuiild it back stock thats why i was considering the 11.5:1 or 12:1. My pistons are still good but my one of my rods is bad and i figured might as well replace them now that its out. As far as cams i plan on getting some skunk 2 stage 2's in a while but figured the ctr cams would do for now. I heard they are better then itr cams. But i also heard they were good for boost only.
Old Jan 5, 2007 | 06:49 PM
Suspetise...
Default Re: (SiTR)
Is the only problem a screwed up rod? If so, skip all this other nonsense, it's not worth the money for 0.5 point bump in CR. Just replace the rod and be done with it.
Old Jan 5, 2007 | 07:12 PM
doood's Avatar
how do you know the rod is bad? what's wrong with it?
Old Jan 5, 2007 | 11:05 PM
SiTR's Avatar
Default Re: Rebuilding on a budget (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">how do you know the rod is bad? what's wrong with it?</TD></TR></TABLE>
i spun two bearings and when we took it apart and took it to the machine shop they told me a rod was shot.
Old Jan 6, 2007 | 11:02 AM
doood's Avatar
if you spun bearings i'd be concerned about your crank too
Old Jan 6, 2007 | 04:57 PM
SiTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">if you spun bearings i'd be concerned about your crank too</TD></TR></TABLE>
i already got another type r crank aswell, i just cant decide whether to build it back stock or if it would even be worth it to raise it from 11:1 to 12:1?
Modified by SiTR at 10:28 PM 1/6/2007
spidy3
Oct 20, 2009 04:02 AM
ek9800
Apr 22, 2005 10:36 AM
itr501
Jun 15, 2002 01:52 AM
blazin
Dec 4, 2001 06:34 AM
StinkyTofu
Oct 22, 2001 09:30 PM
