DP flange leaking..how to seal it??
my flange were the dp meets the turbo is leaking..it seems when we made the dp it must of warped...what can i use on this to stop the leaking?..can i get it plained flat?..or will high heat silcone keep?? its a garret t3to4b 7bolt flange
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowbunny »</TD></TR><TR><TD CLASS="quote">were would i find a gasket?...could i make my own?</TD></TR></TABLE>
Of couse you could, or you can try http://www.atpturbo.com
http://www.atpturbo.com/Mercha...e=GSK
4 bolt or the 5 bolt design ? They don't have 5 bolt but they could probably make you one. I'm sure someone else sells one. To me, it would just be worth it to pay the $7 bucks.
ok.. First, remove DP and see if you can beltsand the flange FLAT, take your time.
Next, when you re-install it, give a bead of high temp silicone/high temp gasket maker on the DP, this will help fill any low spots, let it dry before you start the engine. I cant remember the EXACT name of the stuff you want to use.. Its sold at automotive stores in the chemical dept, it comes in a little tube, mine was red, And it says on the package (designed for 4 cyl turbocharged engines) go figure.. Anyways, gaskets are too expensive, just use the red stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">ok.. First, remove DP and see if you can beltsand the flange FLAT, take your time.
I was going to add, most of the time gaskets are not needed, unless the surface is no longer flat.
</TD></TR></TABLE>I was going to add, most of the time gaskets are not needed, unless the surface is no longer flat.
I have been as well looking for a 5 BOLT GASKET, I think after some reasearch though I will just use high temp silcone gasket maker.
Will the high temp silcone gasket hold up?
i have had this problem for a while ive tried several gasket makers and they eventually turn into ash because of the heat. either find a metal gasket, sand the flange, or get a new flange. i am gonna make a new down pipe and use a vband so that i dont have to deal with the flange, they always warp after time.
boostincoupe
Aug 3, 2006 09:20 PM
Lilkong
Dec 18, 2004 07:46 AM
Matt B
Mar 27, 2004 10:57 AM
