Smoke Everywhere
Old Jan 4, 2007 | 11:33 AM
Midori Green's Avatar
Default Smoke Everywhere
Im about to trade my 96 single cam hatch for a 94 bubble with a gsr engine. Im not thinking twice about the trade because the car is clean. The only problem is that the engine smokes like crazy and the engine idles bad... to me it just feels like this thing has been raced several times. Any suggestions? And how do I stop it from smoking so much.
Old Jan 4, 2007 | 11:35 AM
allricedout's Avatar
just piston rings
Old Jan 4, 2007 | 11:42 AM
Default Re: (allricedout)
How much you think those will cost?
Old Jan 4, 2007 | 12:09 PM
xsuperxsonx's Avatar
Default Re: (Midori Green)
like the guy before stated .... it would be your piston rings, it could be alot of other things as well , such as valve seals , headgasket.... you could never be for sure its piston rings ...
Old Jan 4, 2007 | 01:27 PM
bigl1986's Avatar
Default Re: Smoke Everywhere (Midori Green)
the least of your worries would be the piston rings
the bad thing might be that the block is cracked and coolent is getting into the piston wall. what color smoke is coming out of the car?
Old Jan 5, 2007 | 06:10 PM
Default Re: Smoke Everywhere (bigl1986)
My car has a single cam and this bubble has a gsr... should i trade (gsr is beat up and smokes)
Old Jan 5, 2007 | 06:37 PM
doood's Avatar
been there done that
he's trying to trade you for a reason. his engine is toast or close to it.
Old Jan 5, 2007 | 06:40 PM
Default Re: Smoke Everywhere (doood)
thats what i was thinkin... but what if I just change the piston rings and the headgasket... it would be an amazin deal
Old Jan 5, 2007 | 06:57 PM
what do you guys suggest I replace on the engine?
Old Jan 5, 2007 | 07:08 PM
doood's Avatar
first figure out what is wrong with it then go from there
Old Jan 5, 2007 | 08:29 PM
helpmycivic's Avatar
well i dont really know if the trade would be fair, if his motor is shot then i would say not unless its an easy fix, i would ask him what he did to it and see if you can find out whats wrong with it before you trade.
Old Jan 5, 2007 | 08:36 PM
Turbo_y8's Avatar
Default Re: Smoke Everywhere (helpmycivic)
sounds to me like your buying a problem.
Old Jan 5, 2007 | 08:37 PM
if you could do ure own work it would be worth the trade definitley......no matter what the head needs to come off first, then u can look at it from there.
watisjdm
May 20, 2010 03:21 PM
ThatsMyEG
Oct 20, 2005 02:32 PM
EHwithPotential
Sep 23, 2004 07:04 PM
trev4
Jul 15, 2004 06:32 PM
