where kinda stuck i got a question
we put a a ls vtec in a ls and i wanna know if i hook up a knock sensor???? the wiring is from the ls....i have the wiring for the gsr it came .....
you can run a direct hardline from the sensor into the empty slot on the LS harness (the plugs that connect to the ECU in the cabin) for the knock sensor (given youre using a VTEC ecu)..Youre going to need a pin to attatch to your hardline
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cviccoupe »</TD></TR><TR><TD CLASS="quote">what will happen if i dont hook it up</TD></TR></TABLE>
if it is a stock ECU that isnt chipped to ignore the knock sensor...Then it will throw codes and probably prevent VTEC from engaging
dem0nk1d
Feb 14, 2007 04:03 PM
Big Dick Bandit
Sep 28, 2003 04:54 PM
