eg shocks on an ek?
Old Jan 4, 2007 | 06:33 AM
cbmprelude's Avatar
* B A N N E D *
Default eg shocks on an ek?
will the stock shock assembly (spring, shock, top hat...) from a 95 si fit a 98 cx civic without any modification? thanks
Old Jan 4, 2007 | 07:07 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: eg shocks on an ek? (cbmprelude)
bump
Old Jan 4, 2007 | 07:15 AM
EL Vap133's Avatar
Rears will not fit right, the LCA on an EK is thinner than the EG making the fork on the rear shock of the EG wider. Fronts will fit.
Old Jan 4, 2007 | 07:58 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: eg shocks on an ek? (EL Vap133)
ohh ok, thanks
Old Jan 4, 2007 | 08:04 AM
MidwestSiR's Avatar
you can use washers in the rear to fit them and make up for the wider EG forks
Old Jan 4, 2007 | 08:54 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: (MidwestSiR)
is that safe, and how much washerage is nesscary?
Old Jan 4, 2007 | 08:56 AM
MidwestSiR's Avatar
coilover companies usually include washer/spacers with coilover setups so they can make them 92-00 civic compatible. It's perfectly safe and i have no idea how many you'll have to use
Old Jan 4, 2007 | 09:07 AM
cbmprelude's Avatar
* B A N N E D *
the tops hats fit fine? How much space on each side of the washer are we talking here, maybe around a 1/4"? thanks for your help btw
Old Jan 4, 2007 | 09:23 AM
MidwestSiR's Avatar
top hats will fit.. again.. not sure on the spacing
pleej
Suspension & Brakes
Feb 12, 2010 08:27 AM
EGandDArida
14
Jul 20, 2009 01:27 PM
allstarr7
Mar 18, 2008 07:20 PM
truevietluv636
Oct 18, 2006 07:36 PM
MugenHonda
Oct 21, 2003 02:44 PM
