eg shocks on an ek?
will the stock shock assembly (spring, shock, top hat...) from a 95 si fit a 98 cx civic without any modification? thanks
Re: eg shocks on an ek? (cbmprelude)
bump
Rears will not fit right, the LCA on an EK is thinner than the EG making the fork on the rear shock of the EG wider. Fronts will fit.
Re: eg shocks on an ek? (EL Vap133)
ohh ok, thanks
you can use washers in the rear to fit them and make up for the wider EG forks
Re: (MidwestSiR)
is that safe, and how much washerage is nesscary?
coilover companies usually include washer/spacers with coilover setups so they can make them 92-00 civic compatible. It's perfectly safe and i have no idea how many you'll have to use
Re: (MidwestSiR)
the tops hats fit fine? How much space on each side of the washer are we talking here, maybe around a 1/4"? thanks for your help btw
top hats will fit.. again.. not sure on the spacing
