S2000 Steering Wheel into EM1.
Old Jan 4, 2007 | 04:51 AM
4thgenx42's Avatar
Default S2000 Steering Wheel into EM1.
Would anyone know where I can purchase a cheap S2000 steering wheel?
Old Jan 4, 2007 | 07:36 AM
MidwestSiR's Avatar
search the marketplace here... http://www.ebay.com is probably your best bet though..
Old Jan 10, 2007 | 10:43 PM
randomracer's Avatar
Default Re: S2000 Steering Wheel into EM1. (4thgenx42)
i think i still may have one lying around....ill throw it to you for cheap or anything you got to trade... i am up for anything ...dosnt even have to pertain to cars..
Old Jan 10, 2007 | 11:28 PM
blinx9900's Avatar
can you actually put an s2k wheel on an em1?
Old Jan 10, 2007 | 11:38 PM
CRacer21's Avatar
Default Re: S2000 Steering Wheel into EM1. (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">can you actually put an s2k wheel on an em1?</TD></TR></TABLE>
From what I understand, as long as the car and steering wheel are either single- or duel- stage airbag equipped, then yes.
Old Jan 11, 2007 | 04:30 AM
Xtream_V's Avatar
Default Re: S2000 Steering Wheel into EM1. (CRacer21)
Yes it'll all swap directly over no conversions needed.
Old Jan 11, 2007 | 05:19 AM
Bense's Avatar
Is it possible to maintain the SRS function as well?
I wonder if this could work in an EG with SRS
Old Jan 11, 2007 | 05:50 AM
Andres-eh2's Avatar
s2k or Insight wheels are PNP for 96+ Civics. For 92-95 Civics some custom fabbing is needed. Airbag i dont know.
Old Jan 11, 2007 | 08:27 AM
drSquish's Avatar
the SRS harness from the S2000 is a direct plug and play, as long as it is the AP1 wheel,
edit: <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">The following wheels will fit on a 96-00 Civic:
S2000 (AP1)
S2000 (AP2)
Insight
RSX
RSX Type-S
Civic Si (EP3)
Civic Type R (EP3)
Integra Type R (DC5)
Honda Integra (DC5)
The Following Will Have Working Airbags:
Civic Type R (EP3)
S2000 (AP1)
Not sure about any of the other JDM wheels, don't recall if they have single or dual deployment.</TD></TR></TABLE>
https://honda-tech.com/zerothread/1851439
Old Jan 11, 2007 | 08:38 AM
JDM_teh_WIN!!'s Avatar
Default Re: (drSquish)
Does anyone know if the MOMO Hub for the S2K w/the airbag circuit delete work in a 96-00 Civic? That is the question...
If not maybe I'll try and let you know.
Old Jan 11, 2007 | 01:59 PM
Xtream_V's Avatar
Default Re: (JDM_teh_WIN!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if the MOMO Hub for the S2K w/the airbag circuit delete work in a 96-00 Civic? That is the question...
If not maybe I'll try and let you know. </TD></TR></TABLE>
The Momo hub will work fine with the 96-00 civic because thats the hub that i have in my 99 EK when you get it on the box it'll say 99-00civic/s2000 only thing is you wont have a horn untill you figure out how to rewire it, or rig it up to a pressure swicth...wish i could help you out on the horn issue but i'm still trying to figure it out myself
Old Jan 11, 2007 | 02:02 PM
drSquish's Avatar
Does it seriously fit 99-00 Civics only? Then how would the wheel fit 96-98s also?
Old Jan 11, 2007 | 02:05 PM
mtny's Avatar
Ok some of these posts are false. Here is what I know because I had an EM1 w/ an S2K steering wheel.
-your not going to find one cheap (~$350 how much i payed at least, seen for more/less)
-will just bolt on
-horn will work with no modification
-if you want CC to work you will have to mod it.
I'll post a good write up. Brb
Old Jan 11, 2007 | 02:06 PM
mtny's Avatar
Default Re: (mtny)
http://www.ntpog.org/mods/fift...shtml
Very good write up (its in a prelude but it is same with em1, if i remember correctly).
Old Jan 11, 2007 | 02:11 PM
Xtream_V's Avatar
Default Re: (mtny)
my mistake is says 96-00 i was just thinking about my civic when i typed in the numbers
Old Jan 11, 2007 | 11:48 PM
i will dig around tommorw...n let you know ....i think i might have 2 of them....(brother crashed 3 differnet s2000)
Old Jan 11, 2007 | 11:55 PM
SOHC4life 96's Avatar
Default Re: S2000 Steering Wheel into EM1. (randomracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randomracer &raquo;</TD></TR><TR><TD CLASS="quote">i will dig around tommorw...n let you know ....i think i might have 2 of them....(brother crashed 3 differnet s2000)</TD></TR></TABLE>
You got a pm, I'll take the second one or whatever.
Old Jan 12, 2007 | 07:53 AM
ALL_MOTOR_GSR's Avatar
Default Re: S2000 Steering Wheel into EM1. (SOHC4life 96)
so 92-95 civic's need some fabrication to make them work what kind of fabrication cuz ive been looking to put a s2k steering wheel in my hatch sorry if this is off the subject alittle bit
Old Jan 17, 2007 | 12:13 PM
Eyal 951's Avatar
Default Re: S2000 Steering Wheel into EM1. (ALL_MOTOR_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL_MOTOR_GSR &raquo;</TD></TR><TR><TD CLASS="quote">so 92-95 civic's need some fabrication to make them work what kind of fabrication cuz ive been looking to put a s2k steering wheel in my hatch sorry if this is off the subject alittle bit </TD></TR></TABLE>
I need to know also. Whjats required to do it? Any chance in making the airbag usable also in a 95 hatch?
01silivic
Honda Civic (2001 - 2005)
Aug 29, 2008 03:06 AM
grandam
Jan 9, 2008 02:38 PM
Maru Myx
Jun 29, 2007 09:40 PM
SHG_Mike
Apr 4, 2007 05:37 PM
DA9RsIntegra
Jan 8, 2005 04:22 AM
