wiring.
i have a 98 dx hatch, and im doing a power window converion, under my fuel cover in the interior theres 3 clips, and the new floor harness i got has 2 clips in the 3rd one needed? or do i need a diffrent floor harness, the one im using is out of a 98 hx.
there's actually a way to do it with out the floors harness whinch in my opinion is better, heres the link...
https://honda-tech.com/zerothread?id=1762783
I believe it is because your dx has a fuel tank pressure switch and the harness you got doesn't. under the cover you have a plug for the fuel pump, the fuel level sending unit and then a FTP switch. If your car had has it. yor ECU will not see it with the new harness. that means the CEL will light up. you can remove the wires for it and pin them into the new harness and run them separately and be fine.
well here if you go towards the end it show you how to re-pin them ....
http://repo.jackmoves.com/v/erik/album106/album206
primeredsol
14
Dec 21, 2006 10:57 PM
