Mini Me or entire motor swap
Old Jan 3, 2007 | 04:32 PM
rjex99's Avatar
Default Mini Me or entire motor swap
I just bought a 1990 civic lx, the motor is a D15b2. The head is bad though. I also have a d16y5 and trans from a 97 hx. I was wondering if I should do a mini me swap or swap every thing?Would a p28 ecu be the right one to use? And If I do the mini me can I swap the Trans anyway?
Old Jan 3, 2007 | 04:37 PM
CRX Toad's Avatar
Default Re: Mini Me or entire motor swap (rjex99)
The 97 tranny is a hydro tranny and the 88-91 cars are a cable clutch. You can do mini-me swap but what is wrong with using your current tranny?
Old Jan 3, 2007 | 04:41 PM
rjex99's Avatar
Default Re: Mini Me or entire motor swap (CRX Toad)
Shifting is very sloppy. I would like to boost it in the near future and I dont know if the old trans will hold up
Old Jan 3, 2007 | 04:45 PM
bag's Avatar
bag
shifting is sloppy? usually the shifter bushing is the cause of this..as long as the tranny not grinding or acting abnormally leave it be. your tranny can handle boost no problem,,clutch is another story
Old Jan 3, 2007 | 04:54 PM
VRD^sam's Avatar
Default Re: Mini Me or entire motor swap (bag)
i wouldn't do a minime with that bottomend...they have weak rods....just go for a complete D16z6 or a D16y8 with a D16a6 tranny...
Old Jan 3, 2007 | 04:59 PM
rjex99's Avatar
alright, but what about the ecu, the motor is from an obd2 car, and is vtec, the car is obd2, so what is the best route to go for the ecu
Old Jan 3, 2007 | 05:01 PM
rjex99's Avatar
Default Re: Mini Me or entire motor swap (get^bent)
Couldn't I just put a y8 head on the y5 bottom end? I already have the y5 motor and trans due to a roll over.
Modified by rjex99 at 9:38 PM 1/3/2007
Old Jan 3, 2007 | 06:09 PM
rjex99's Avatar
help please, or at least a thread to a similar swap i searched an can't find any.
Old Jan 3, 2007 | 06:28 PM
C_R_X_V_T_E_C's Avatar
any d-series head will swap onto a d-series bottom. so a Y8 head would fit on a Y5 bottom Fo SHo.
Old Jan 3, 2007 | 06:34 PM
rjex99's Avatar
Default Re: Mini Me or entire motor swap (C_R_X_V_T_E_C)
Correct me if im wrong but the y5 head is the econnomy version, the lobes on the cams are not as aggressive of those on the y8, so swapping heads will provide more power.
HCJDM1
12
Jan 28, 2007 05:22 PM
ekcivic9
Oct 3, 2006 10:22 PM
norm13
Jan 23, 2006 03:22 PM
