help vtec solenoid
Old Jan 3, 2007 | 04:12 PM
anht's Avatar
Default help vtec solenoid
i bought a mini me swap from my friend. It has a y7 block and y8 head. Once the engines in my car i noticed It has an oil leak from the vtec solenoid. So i checked the gasket and it looked fine there was no tears/rips, i torqued the bolts down also, then i noticed there was an oil line going to where the pressure switch is at so i took the tube off that looked like this...
i took the tube off and it looked like it was this metal line so oil could come through. I thought there was suppose to be the green plug there?
is this why it might be leaking? i thought the solenoid might be getting to much oil and maybe leaking out? vtec is not set up right now but i would like to kno why its leaking and why the pressure switch is not there?
Old Jan 3, 2007 | 04:36 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: help vtec solenoid (anht)
sorry but ^ thats funny
Old Jan 3, 2007 | 04:58 PM
anht's Avatar
yea thanks its leakin really bad too...
Old Jan 3, 2007 | 05:53 PM
deadline's Avatar
Default Re: (anht)
might just need a new gasket for vtec selinoid...its a lil rubber gasket i forgot wut it was called.....its in the archives somewhere..........?
Old Jan 3, 2007 | 06:22 PM
anht's Avatar
the gasket on it looked fine but im gunna buy one anyway to see if that does anything...its also leaking on the top part of the solenoid.
Old Jan 3, 2007 | 06:32 PM
djsire's Avatar
Default Re: help vtec solenoid (Throwdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Throwdown &raquo;</TD></TR><TR><TD CLASS="quote">sorry but ^ thats funny</TD></TR></TABLE>
so are you gonna tell him that his solenoid is fuccked!.
thats where the oil pressure/vtec swith is suppose to bend yes its green.
go get a new vtec solenoidd. it looks like your friend did some wierd hack job to that.
MAtter of fact sell that motor to someon else. You dont konw what else has gone wrong with that heap/
Modified by djsire at 3:59 AM 1/4/2007
Old Jan 3, 2007 | 07:01 PM
schardbody's Avatar
where does the other end of that hose/line go??? just curious.
Old Jan 3, 2007 | 07:03 PM
anht's Avatar
well my friend got the engine from some guy but ill buy another solenoid and see if it stops leaking hopefully
Old Jan 3, 2007 | 07:04 PM
Brick Top's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">where does the other end of that hose/line go??? just curious. </TD></TR></TABLE>
i'm also wanting to know...
but better yet, why is a hose connected there? is it doing something?
Old Jan 3, 2007 | 07:07 PM
anht's Avatar
this is whats at the other end feeding oil to the vtec solenoid
Old Jan 3, 2007 | 07:08 PM
anht's Avatar
this is why im thinking its leaking because too much oil is getting into the solenoid because its not usually like this?
Old Jan 3, 2007 | 07:11 PM
EJgsr's Avatar
Default Re: (anht)
thats some getto ****...
sorry
i would get a new solenoid to make your car cleaner...
schardbody's Avatar
hmm, that makes no sense at all. the vtec solenoid gets oil from the head, not the pressure switch. i dont understand the reasoning there??? but oh well. i would certainly assume that this is the cause of your leak, too much oil pressure in the solenoid. fix it and cap off that bung in the head. then get a pressure switch.
Old Jan 3, 2007 | 07:12 PM
anht's Avatar
it looked very odd to me i was wondering if anyone else has done this because i dont know what the reason is for it
Old Jan 3, 2007 | 07:14 PM
schardbody's Avatar
Default Re: (anht)
there is no logical reason, unless they didnt have a pressure switch and just needed something to go in its place, but unless he had vtec hardwired or on a RPM switch or something like that it wasnt working.
Old Jan 3, 2007 | 07:16 PM
Brick Top's Avatar
they probably thought you need a vtec oil line for the mini me.
one of the dumbest things i've seen yet.
Old Jan 3, 2007 | 07:22 PM
EJgsr's Avatar
Default Re: (brick top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top &raquo;</TD></TR><TR><TD CLASS="quote">they probably thought you need a vtec oil line for the mini me.
one of the dumbest things i've seen yet.</TD></TR></TABLE>
hehe
Old Jan 3, 2007 | 07:33 PM
anht's Avatar
the guy who had the engine before had vtec wired to a vtec controller
Old Jan 4, 2007 | 05:16 AM
djsire's Avatar
Default Re: (anht)
i would suggest you get a new solenoid and close up that tap.
Old Jan 4, 2007 | 07:43 AM
chad's Avatar
Moderator
Default Re: (djsire)
they are getting the oil to feed vtec from that line onthe other side of the head because they didn't pull the oil feed line out of the block when doing the mini me swap!!!
GHETTO....
and it probably won't work that way
it is just feeding oil back down
did you even have vtechk?
Old Jan 4, 2007 | 07:47 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">hmm, that makes no sense at all. the vtec solenoid gets oil from the head, not the pressure switch. i dont understand the reasoning there??? but oh well. i would certainly assume that this is the cause of your leak, too much oil pressure in the solenoid. fix it and cap off that bung in the head. then get a pressure switch.</TD></TR></TABLE>
I'm thinking the dude rigged it up like you would for LS/VTEC.
Yeah I know that sounds kinda crazy but maybe he thought there wouldn't be any taps in the block for the oil to get to the VTEC solenoid so he ran his own...
Who cares, if I was the OP, new solenoid, DEFINITELY.
******* hack job.
Old Jan 4, 2007 | 10:42 AM
schardbody's Avatar
Default Re: (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">they are getting the oil to feed vtec from that line onthe other side of the head because they didn't pull the oil feed line out of the block when doing the mini me swap!!!
GHETTO....
did you even have vtechk?</TD></TR></TABLE>
chad FTW, i didnt even think about the oil control in the block, haha, tards.
Sk8NJ91
Dec 3, 2012 06:56 PM
yoffer
Aug 21, 2012 03:23 PM
my_honda_
Dec 22, 2008 04:32 AM
hybrid1990crx
Aug 12, 2005 10:41 AM
bboylito
Mar 3, 2005 04:14 AM
