Can I drive (move) my EG with the airbags disconnected?
Old Jan 3, 2007 | 12:25 PM
Fuster_Cluck's Avatar
Default Can I drive (move) my EG with the airbags disconnected?
I placed the red plug into the harnesses as stated in the manual. Can I drive the car into the garage safely? I should of pulled the dash in the garage, but the sunshine was too nice
I don't want the bag to go off if the car is started. Now that I think about it.... it (Helms) doesn't mention anything about starting the car with the bags unplugged like it states 3 or 4 times to make sure the red plug is installed before dropping the steering column.
Anyone know for sure if this is ok?
Driveway is on a slant and my skiny *** is not strong enough to push it back in the garage even with the hood, fenders, doors, and complete interior removed
Well, I don't think at least..... I'll give it a try
Old Jan 3, 2007 | 12:30 PM
Default Re: Can I drive (move) my EG with the airbags disconnected? (Hybrid93Hatch)
Never mind, underestimated myself. Took a hard effort, but I managed to push it up into the garage
Old Jan 3, 2007 | 12:41 PM
EG93si's Avatar
Default Re: Can I drive (Hybrid93Hatch)
if its unhooked, theres a good chance it wont go off, just to save you some pushing in the future
Old Jan 3, 2007 | 12:43 PM
NCC Admin's Avatar
no there wouldn't have been a problem driving the car with the airbags unplugged the only thing that would have happened is the sensor would notice there was a problem in the system so the light on the dash would have remained on
Old Jan 3, 2007 | 02:26 PM
allricedout's Avatar
no you can plug/unplug the sensors as much as you want....and once you connect them all back the srs light will turn off every time no exceptions.
Old Jan 3, 2007 | 04:04 PM
VRD^don's Avatar
Default Re: (allricedout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout &raquo;</TD></TR><TR><TD CLASS="quote">no you can plug/unplug the sensors as much as you want....and once you connect them all back the srs light will turn off every time no exceptions. </TD></TR></TABLE>
actually you have to take it back to honda to have the system reset..it's gonna stay on..or is this just for ek's?
Old Jan 3, 2007 | 04:29 PM
EeeJayEight's Avatar
Default Re: (k_motor)
you can reset it yourself.. i did this on my ek when i put the stock wheel back on..
Old Jan 3, 2007 | 04:39 PM
Fabritory's Avatar
Default Re: (EeeJayEight)
Maybe ya'll should check your muffler bearings, turn signal fluid and then change the summer air to the winter air in your tires..JUST A TIP FROM WYOTECHS FINNEST! Airbags are electronically armed and if the plug is not connected it cant go off. READ YOUR HELMS MANUAL AGAIN
Old Jan 3, 2007 | 09:51 PM
EG93si's Avatar
Default Re: (Fabritory)
i dont see why you have to hate, i nicely showed him that he kinda over thought it, no go answer a question not hate on someone who has already been answered.
Old Jan 3, 2007 | 09:52 PM
JDM-EJ1's Avatar
Yes, if you unplug the airbags it is okay to drive the car. It isn't legal, but the car will drive fine.
Old Jan 4, 2007 | 05:18 AM
Thanks for clearing this up
Old Jan 4, 2007 | 01:38 PM
bigl1986's Avatar
make sure you disconnect the battery before removing any airbag! let the car sit for like 5 min with no power then mess with the airbags. my buddy had a bad run in with that
hondur
12
Mar 16, 2016 10:54 PM
MidwestSi
Jun 17, 2010 08:50 PM
strtkart
Mid-Atlantic (Sales)
May 20, 2007 08:59 PM
Rogue Si
Feb 13, 2003 07:56 PM
