Clunking sound when turning
Old Jan 3, 2007 | 11:13 AM
zach1288's Avatar
Default Clunking sound when turning
I hear a clunking sound when i make turns. Like clunk..clunk..clunk untill i straighten the wheel. It also clunks alittle when i start from a stop light. Like soon as i start moving it clunks once or twice but its the worst around turns?
Old Jan 3, 2007 | 11:16 AM
RARE_EG2's Avatar
Default Re: Clunking sound when turning (zach1288)
sounds like it might be your axle(s)..if you make a left turn..its from your passenger side axle..if you make a right turn..its from your driver side axle..
Old Jan 3, 2007 | 11:40 AM
zach1288's Avatar
Default Re: Clunking sound when turning (RARE_EG2)
Do they make a "clunking" sound? I thought they made more of a poping sound?
Old Jan 3, 2007 | 11:49 AM
excivicboy96's Avatar
cv joint is clunking. try a visual check first/ check the rubber boots on them to make sure they aren't exposing anything inside
Old Jan 3, 2007 | 11:53 AM
zach1288's Avatar
Default Re: Clunking sound when turning (excivicboy96)
Will they also clunk when i start from a dead stop like i said?
Old Jan 3, 2007 | 11:57 AM
trboeclpse98's Avatar
Does your steering wheel move when it clunks? If it does it could be your rack & pinion, but I would check your axles first.
Old Jan 3, 2007 | 12:00 PM
zach1288's Avatar
Default Re: (trboeclpse98)
No the steering wheel is fine.
Old Jan 3, 2007 | 12:37 PM
johnecon2001's Avatar
Default Re: (zach1288)
Check your CV boots then. If they're ripped or are covered in an oily substance.. they joint is probably bad. You can replace just the joint, but while your down there you might as well replace the whole axle.
Old Jan 3, 2007 | 12:40 PM
pdiggitydogg's Avatar
Depending on how loud/heavy the "clunk" is...it could be lower ball joints.
Axles "click" (similar to tapping a pen on your desk)
Old Jan 5, 2007 | 01:28 PM
zach1288's Avatar
I forgot to mention something, when i replaced my axle seal a few weeks ago and i put the axle back in the tranny and moved it to line up the splines on the spindle side i heard the noise? Im wondering if my differential / tranny is fucked up?
Old Jan 7, 2007 | 03:07 PM
zach1288's Avatar
bump
Wazup
11
Oct 21, 2022 12:47 PM
midnyte
Suspension & Brakes
38
Jun 5, 2009 01:29 PM
b18c-1
May 17, 2006 04:25 PM
GodofRage
13
Jan 8, 2005 08:27 AM
EKlat_9
13
Aug 8, 2004 06:29 PM
