how much oil?
Old Jan 3, 2007 | 09:09 AM
TunerShark's Avatar
Default how much oil?
i know this might sound really newbish but i dont have my manual and this is the first oil change im doing since i bought the car. everything is stock oil pan wise
i know the capacity is 3.8 quarts, but should i fill her up with the full 3.8? or more or less?
thanks
Old Jan 3, 2007 | 09:11 AM
B18CivicEH2's Avatar
Default Re: how much oil? (TunerShark)
pick up 4 bottles....
Old Jan 3, 2007 | 09:12 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: how much oil? (B18CivicEg)
I allways throw in 4.
Old Jan 3, 2007 | 09:14 AM
TunerShark's Avatar
Default Re: how much oil? (wrx-killer-Sti eater)
k thanks.
Old Jan 3, 2007 | 09:15 AM
Jakester9500's Avatar
i do 3 quarts oil, one quart lucas oil stabilizer. I love that stuff
Old Jan 3, 2007 | 10:00 AM
Default Re: (Jakester9500)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jakester9500 &raquo;</TD></TR><TR><TD CLASS="quote">i do 3 quarts oil, one quart lucas oil stabilizer. I love that stuff</TD></TR></TABLE>
i seen that stuff at Autozone....how is it??
Old Jan 3, 2007 | 10:10 AM
E46Kid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CivicEg &raquo;</TD></TR><TR><TD CLASS="quote">pick up 4 bottles....</TD></TR></TABLE>
Old Jan 3, 2007 | 10:33 AM
cwf1988's Avatar
Default Re: how much oil? (Em1Kid)
get 12 bottles and put it all in.. lol... 4 dude
Old Jan 3, 2007 | 10:36 AM
Default Re: (B18CivicEg)
I like it a lot. My old motor use to burn through about a quart of oil a month, put in some lucas, and it stopped burning that much. Plus, it is just good for the life of the engine.
Old Jan 3, 2007 | 11:03 AM
chrisw85's Avatar
Read this: http://www.bobistheoilguy.com/...s.htm
and you'll change your mind about additives. If your burning oil, I suggest using a thicker rated cSt oil (or partially mixing some 15w40 Mobil Delvac in their), or fixing the source of burning (be it worn valve seals, or carbon gunk buildup giving false seals)
Old Jan 3, 2007 | 11:14 AM
NCC Admin's Avatar
honestrly I always put in just the 3.8 if you over fill the oil too much it can blow out the main seal so I don't like to chance it and put in just the required ammount
Old Jan 3, 2007 | 11:17 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: how much oil? (cwf1988)
i concur, put 4 in and you should be good to go. make sure you park it on a level surface so you get all the old oil out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwf1988 &raquo;</TD></TR><TR><TD CLASS="quote">get 12 bottles and put it all in.. lol... 4 dude </TD></TR></TABLE>
i knew a guy that did that once. luckily i got there before he started the motor. he though you filled it up till you saw it... lol
Old Jan 3, 2007 | 11:23 AM
Default Re: (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chrisw85 &raquo;</TD></TR><TR><TD CLASS="quote">
and you'll change your mind about additives. If your burning oil, I suggest using a thicker rated cSt oil (or partially mixing some 15w40 Mobil Delvac in their), or fixing the source of burning (be it worn valve seals, or carbon gunk buildup giving false seals)</TD></TR></TABLE>
nice info there....LUCAS FTMFL
Old Jan 3, 2007 | 11:52 AM
well no more lucas for me. there is a new engine going in my car now, and lucas is not touching it!
Old Jan 3, 2007 | 12:52 PM
NCC Admin's Avatar
Default Re: how much oil? (Rodney)
hahaha ya I know someone who did that too and even more he is a member on here lol
Old Jan 3, 2007 | 01:39 PM
allricedout's Avatar
.2 isnt much more.
QUICK STORY: at the dealership where i work there was this new lube tech who drained a total of 4 transmissions and put more oil in the block itself.....every one of the customers came back with a check engine light etc. and said thier car was acting up...then he backed up into the garage door with a bike rack ontop of an x-terra and screwed everything up, my manager was so pissed about everyhing and well...i can say i never saw that kid again.
Old Jan 3, 2007 | 02:11 PM
junior40er's Avatar
Default Re: how much oil? (NCC Admin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCC Admin &raquo;</TD></TR><TR><TD CLASS="quote">hahaha ya I know someone who did that too and even more he is a member on here lol</TD></TR></TABLE>who you talking about? That idiot must be a NoOb!! lol
Old Jan 3, 2007 | 03:07 PM
postman's Avatar
Default Re: how much oil? (junior40er)
additives are bad. dont use them.
Old Jan 3, 2007 | 04:19 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerShark &raquo;</TD></TR><TR><TD CLASS="quote">i know this might sound really newbish but i dont have my manual and this is the first oil change im doing since i bought the car. everything is stock oil pan wise
thanks</TD></TR></TABLE>
You fill it until the oil level in the sump reaches the top dot on the dip-stick (while the car is sitting level) - no more, no less. The actual amount doesn't matter. Always remember to re-check and top off after starting the engine - the level drops slightly once the new oil filter fills up.
Do not use oil additives.
Old Jan 4, 2007 | 11:19 AM
cwf1988's Avatar
i knew a guy that did that once. luckily i got there before he started the motor. he though you filled it up till you saw it... lol [/QUOTE]
lol hahahaha thats good, i would have smacked the **** of out him
Old Jan 4, 2007 | 12:00 PM
EG2Driver's Avatar
wow that is good info there.
Can Lucas can be good for storing cars to avoid dry starts 4 months after then engine hasn't been run?
ahron
Sep 9, 2007 06:59 PM
John 07
Feb 3, 2007 06:58 AM
jdm-ray
Jul 2, 2005 09:29 PM
Y2A
Nov 17, 2004 05:31 AM
neilff
Jul 29, 2003 07:20 AM
