left headlight is dim please help
Ok so I bought an eg and the left hand side headlight is dim, I swaped the light bulbs and figured that the problem would of probably went away when I changed the light bulbs but it didn't, what do u guys think this might be? And what can I do to fix it, I need help cause I'm about to start doing a wire tuck but I have to tackle this before I start on that, any help would be greatly appreciated, thnx in advance
most likely it isn't grounded right. it happened to my friends hatch as well. theres like a clip of connectors beside the headlight harness, along the fender. make sure that connected. if its not that, maybe its the harness itself.
most likely needs to be re-grounded like the other guy said. get a multimeter and test the lamps ground to it's 12v and see if it's 12v. if it's like 6v... then hookup the lead to the battery ground and test ur 12v. if it's 12v then it's a bad ground. if it's still 6v then you'll need to rewire that 12v source. and 6v is just a reference.. it could 11.0 for all i know.
ebp 99 si
13
Jun 3, 2004 11:20 AM
