Honda S2000 Honda S2000
We need a crap load of help please
Old Jan 3, 2007 | 01:15 AM
808k20z3's Avatar
Default We need a crap load of help please
ok me and my friends have been trying 2 get the trans off of his 03 S2K 2 change his clutch but the trans wont come off! we droped the motor and everything removed all the bolt and still its stuck. the trans twists but it wont come off. please help.maybe instructions or sumtin or a diaphragm would help!thanks!
Old Jan 3, 2007 | 08:53 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: We need a crap load of help please (808k20z3)
you have the motor and tranny out of the car???
extrat work then needed if u ask me..
sometimes the shafts are in there pretty good so once everything is out with a flathead screwdriver pry between the block and tranny and work yourway around...
Old Jan 3, 2007 | 10:02 AM
Mr.E.G.'s Avatar
there is a specific technique that sint that obvious. i remember my buddy talking about it but i cant remember the specifics. let me call him and have him refresh my memory.
Old Jan 3, 2007 | 10:10 AM
Mr.E.G.'s Avatar
Default Re: We need a crap load of help please (Mr.E.G.)
ok i called my buddy and he said that he has done this about a dozen times. the easiest way to avoid scratching the **** out of the fire wall is to remove arm (i think thats what he said) and then lower the front subframe, engine and all, about 2.5 to 3 inches. that will give you plenty of clearance and you take it off just like any other tranny.
i hope that helps. and im sorry i personally cant relay the method as im sure at least some part of his description has been lost in translation.
Old Jan 3, 2007 | 10:12 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
thing is he said he dropped the motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808k20z3 &raquo;</TD></TR><TR><TD CLASS="quote">ok me and my friends have been trying 2 get the trans off of his 03 S2K 2 change his clutch but the trans wont come off! we droped the motor and everything removed all the bolt and still its stuck. the trans twists but it wont come off. please help.maybe instructions or sumtin or a diaphragm would help!thanks!</TD></TR></TABLE>
so with that said i think its out unless he means something different
Old Jan 3, 2007 | 01:42 PM
Curiouz_G's Avatar
search "us2bwrx" on s2ki.net. its in the Mid-Atlantic forums. a guy did a tranny swap w/ pics and details.
Old Jan 3, 2007 | 02:01 PM
Mr. Projekt's Avatar
* B A N N E D *
Did you take off the clutch fork?
What about the top starter bolt?
Old Jan 3, 2007 | 03:07 PM
dkim48's Avatar
Default Re: We need a crap load of help please (FR-MOB: Projekt)
i bet it's the fork...a lot of people have problems with it. once you remove that it will fall apart very easily. good luck
Old Jan 3, 2007 | 05:29 PM
Mr.E.G.'s Avatar
Default Re: We need a crap load of help please (S@nt0s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">thing is he said he dropped the motor
so with that said i think its out unless he means something different</TD></TR></TABLE>
he also said he wants a "diaphragm". i can only do so much
Old Jan 3, 2007 | 05:53 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">
he also said he wants a "diaphragm". i can only do so much </TD></TR></TABLE>
Old Jan 4, 2007 | 03:48 AM
808k20z3's Avatar
where is the fork? we pried the tranny off the block about 3 to 4 inches and twist the tranny back and forth pull and pull but still nothing we even tied a rope around the tranny and hooked it up 2 my truck and it wont budge! all of us have frot wheel drive cars so this is new 2 us! please help if u can thanks!
Old Jan 4, 2007 | 05:03 AM
JDM knowledge's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808k20z3 &raquo;</TD></TR><TR><TD CLASS="quote">where is the fork? we pried the tranny off the block about 3 to 4 inches and twist the tranny back and forth pull and pull but still nothing we even tied a rope around the tranny and hooked it up 2 my truck and it wont budge! all of us have frot wheel drive cars so this is new 2 us! please help if u can thanks!</TD></TR></TABLE>i think you ladies need men to help you.
I joke I joke...
Old Jan 4, 2007 | 05:43 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: We need a crap load of help please (JDM knowledge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM knowledge &raquo;</TD></TR><TR><TD CLASS="quote">i think you ladies need men to help you.
I joke I joke...</TD></TR></TABLE>
couldnt have said it better....
sometimes the pitch fork gets caught you just have to "play" with it! seriously!
Old Jan 4, 2007 | 08:29 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808k20z3 &raquo;</TD></TR><TR><TD CLASS="quote">where is the fork? we pried the tranny off the block about 3 to 4 inches and twist the tranny back and forth pull and pull but still nothing we even tied a rope around the tranny and hooked it up 2 my truck and it wont budge! </TD></TR></TABLE>
Sig worthy but you don't deserve the space.
Does the tranny come straight off the motor or at an angle?
Old Jan 4, 2007 | 10:49 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Projekt &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jan 4, 2007 | 11:27 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkim48 &raquo;</TD></TR><TR><TD CLASS="quote">i bet it's the fork...a lot of people have problems with it. once you remove that it will fall apart very easily. good luck</TD></TR></TABLE>
x2 and thank you.
Modified by Mr. Projekt at 1:49 PM 1/4/2007
Old Jan 4, 2007 | 11:30 AM
Default Re: We need a crap load of help please (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">x2 and thank you. BTW this picture is for that one guy that said you can't pull the tranny and motor as one, out of the car. Eat my shorts young man.
that is such a hurtful picture. Mortal Kombat-ish
Old Jan 4, 2007 | 11:31 AM
* B A N N E D *
The resulting satisfaction more than made up for the hurt. F20 came out, F22 with 9k redline came in.
dusterbd13
17
Aug 2, 2009 06:20 AM
SECURITY
11
Sep 8, 2005 12:13 AM
Ls91sI
Jul 14, 2005 01:35 AM
catch22-101
Dec 18, 2004 04:37 PM
Mario
Mar 15, 2002 07:36 PM
