shift knob problem
Old Jan 2, 2007 | 07:05 PM
hcvc05's Avatar
Default shift **** problem
So my gf got me a DC5R shift **** for christmas and when I installed the shift pattern was not facing the way its supposed to. I was wondering if anyone knows what the problem could be. Anything is appreciated thanx.
Old Jan 2, 2007 | 07:29 PM
eMpAtHy's Avatar
Default Re: shift **** problem (hcvc05)
unless the threads are screwed (which i doubt they are because im almost certain its made with a machine). are u sure its on fully tight? you dont have to over tighten it. like the stock one can actually turn some more, but u dont turn it all the way.
Old Jan 2, 2007 | 07:38 PM
hcvc05's Avatar
Default Re: shift **** problem (eMpAtHy)
yeah thats what I thought but if I dont tighten it all the way when I shift it becomes loose.
Old Jan 2, 2007 | 08:02 PM
ballerchild's Avatar
try using some washers or a nut under the shift **** to have the numbers facing forward.
Old Jan 2, 2007 | 08:50 PM
GradyDC5's Avatar
Yeh, you have to have a nut that locks the **** in place. The s2000 uses one for it's ****. Which is what I have for my s2k leather wrapped ****. You can buy one from Honda. It's a dollar I think. Solve your problem
Nevermind I thought you could see the nut.
Old Jan 2, 2007 | 09:28 PM
mister x's Avatar
Default Re: (ReallySlowEg)
You can also use a 10mm x 1.50 thread metric nut ($.10?) until you find a genuine good for 20 WHP OEM Honda lock nut.
Old Jan 2, 2007 | 09:41 PM
20CiviC02Si's Avatar
Yeah! The HOP (Honda Original Parts) ***** come with a reverse thread nut that you place on the the shifter and adjust the **** till it's tight and in the right position.... However you can do what i did, and not use the nut and stick paper in the **** and tighten it down until it fits just right! I used Orbit gum wrappers and kept adding them until the **** was where i wanted it! You can use anything that will act as a shim to get it where you want it to be, also you don't have the gaudy nut to look at! Kinda ghetto i know, but it works.... No one will know but yourself!
Old Jan 2, 2007 | 10:30 PM
Kantot's Avatar
what i did was stuck bits of paper towel in the shift **** and tightened it and lined it up. i didnt want to use the nut because it would sit higher and i didnt want that.
Old Jan 2, 2007 | 10:51 PM
GradyDC5's Avatar
90310-ST7-Z00 That's the part number.... price is 1.20 will most likely be free shipping
Old Jan 3, 2007 | 01:02 PM
hcvc05's Avatar
hey thanx for all the help guys. I found the nut that goes with it and seems a bit better then the way it was.
skata89
Oct 20, 2005 11:15 AM
Ludester
Dec 30, 2002 04:06 PM
andrewasf77
Nov 10, 2002 11:50 AM
mickey513
Jun 19, 2002 05:18 PM
civicboy95
May 6, 2002 10:48 AM
