shift knob
Old Oct 19, 2005 | 04:49 PM
skata89's Avatar
Default shift ****
i got a short shifter and when i put the shift **** on its backwards. how do i fix that?
Old Oct 19, 2005 | 05:01 PM
Racermech's Avatar
Default Re: shift **** (skata89)
you could try to wrap some teflo tape on the last threads so it will tighten a little sooner.
Or sell that **** and get one that does not have numbers on it.....
Old Oct 19, 2005 | 05:08 PM
TurdBlown Teg's Avatar
the numbers help me.....
Old Oct 19, 2005 | 06:40 PM
mystikalstriker's Avatar
Default Re: (kevin716)
then sell the **** and get the ones were you can stick the pattern on the shift console. besides how hard is it to remember..
1 3 5
I-+-I
2 4 R
Old Oct 19, 2005 | 07:28 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (mystikalstriker)
get the spoon one like me then you can tighten the **** down and put the 12345R stick on after.
Old Oct 19, 2005 | 07:41 PM
popuppiston's Avatar
get a nut and put it on first then the shift ****, tighten the shift **** to where you want it the tighten the nut to the shift **** to lock it in place, kind of like a jam nut
Old Oct 19, 2005 | 07:49 PM
SlamminS85's Avatar
Default Re: shift **** (popuppiston)
^ best solution yet ^
Old Oct 19, 2005 | 08:28 PM
1997GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by popuppiston &raquo;</TD></TR><TR><TD CLASS="quote">get a nut and put it on first then the shift ****, tighten the shift **** to where you want it the tighten the nut to the shift **** to lock it in place, kind of like a jam nut
this nut comes with all quality shift *****...came with my skunk2 10th anniversary ****
Old Oct 19, 2005 | 10:00 PM
95gsr2203's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevin716 &raquo;</TD></TR><TR><TD CLASS="quote">the numbers help me.....</TD></TR></TABLE>
how the hell does it help? what do you look down every time you shift? i would say maybe for looks but thats about all. its not like anything changes or moves. its the same ol everytime.
Old Oct 20, 2005 | 01:50 AM
suzawa94's Avatar
Default Re: (95gsr2203)
i had a similar prob with my skunk2 ****. when turned all the way (didn't want to use locking nut) numbers would point in a angle like this- / upside down. i used a tap and tapped as far down as i could. there is a lip @ the bottom of the thread which should stop the tap from moving further. this gave me about 3/4 turn more on the **** which placed the numbers straight and centered.
Old Oct 20, 2005 | 11:15 AM
MVP's Avatar
MVP
Default Re: (suzawa94)
Locking nut
pfcle
Honda Civic (2006 - 2015)
May 17, 2007 08:55 PM
tnewhallSi
Mar 31, 2006 11:44 PM
andrewasf77
Nov 10, 2002 11:50 AM
joemama
May 24, 2001 05:01 PM
