f20c engine
Old Jan 2, 2007 | 06:26 PM
million's Avatar
Default f20c engine
is it possible to fit an s2000 engine into a 98 civic hatchback?
Old Jan 2, 2007 | 06:30 PM
JDM KID 510's Avatar
Default Re: f20c engine (million)
Anything can be done. Just a lot of money you have to invest in it.
Old Jan 2, 2007 | 06:32 PM
mugenEGG's Avatar
ive seen it done in a eg hatch...the retard had over 500 lbs of fiberglass and audio stuff in it tho
still ran 13's
Old Jan 2, 2007 | 06:52 PM
turnsignalandy's Avatar
Default Re: (mugenEGG)
search
click the magical red button, and select 92-00 in one of the options then select archived threads then type in f20c.
https://honda-tech.com/zerosearch holy expletive look what i found.
Old Jan 2, 2007 | 07:00 PM
Default Re: (turnsignalandy)
If you can' help out, dont post at all.
Here what I found. Take your time and read threw it.
https://honda-tech.com/zerothread?id=1647096
https://honda-tech.com/zerothread?id=1305286
https://honda-tech.com/zerothread?id=1144830
Old Jan 2, 2007 | 07:26 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by million &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to fit an s2000 engine into a 98 civic hatchback?</TD></TR></TABLE>
This question used to be asked fairly frequently.
Yes, it's possible. It has also been done several times.
No, it's not worthwhile or cost-effective in any way. If you have to ask, you probably don't have the imagination or the skills to carry out the project. Do you have a five-digit budget? Can you fabricate?
For the amount of money you'd spend on swapping that shitty engine into a shitty Civic chassis, you could easily buy a used S2000 - which is a well-engineered overall package, and not just an engine, or drivetrain, or whatever.
The F20C1 is nothing spectacular anyway. You'd probably be better off looking into a K-series, which has the same power potential minus the extra weight and swap complexity.
Old Jan 2, 2007 | 07:32 PM
h8ted ek's Avatar
Default Re: f20c engine (Targa250R)
goodluck, id rather use other engines if anyone ever planning on that route ie civic chasis rwd, or a different chasis for the f20c. I dont know how easily a f20c can be bought or bought cheap but ls1, american big blocks is easier come by.
Old Jan 2, 2007 | 07:34 PM
EL Vap133's Avatar
MugenPower7642
May 21, 2007 09:29 PM
smashedInSi
Jan 28, 2004 10:32 AM
10K2HVN
Jul 21, 2003 11:18 AM
IN VTEC
Feb 16, 2003 04:35 PM
Group 03
Sep 10, 2001 03:35 PM
