Looking for a breakdown of motor..
Old Jan 2, 2007 | 05:29 PM
jdm_DC2R's Avatar
Default Looking for a breakdown of motor..
Well, ive searched and search and havent found anything that im looking for to help me with my build.
Basically i need a diagram or parts list, of rebuilding the entire block. i want to make a list of parts that ill need to replace, ie, rod bearings, main bearings, etc, etc. I'll be goin with the Wiseco pistons 81.5mm overbore, and basically i want to replace everything else with honda factory parts consisting in the block.
i just want to see a list so i dont end up missing anything that i should change.
thanks!
Old Jan 2, 2007 | 05:36 PM
vtec.dc2's Avatar
Default Re: Looking for a breakdown of motor.. (jdm_DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">Well, ive searched and search and havent found anything that im looking for to help me with my build.
thanks!</TD></TR></TABLE>
honda make the gasket kit, upper and bottom? then bearings, oil pump if needed, water pump if needed and thats about it.. get arp headstuds and timing belt/tensioner
Old Jan 2, 2007 | 05:42 PM
itralex's Avatar
Cylinder Head Complete Gasket Kit - 06110-P73-A03
Cylinder Block Complete Gasket Kit - 06111-PR4-020
Oil Pump assembly - 15100-P72-A01
Water Pump - 19200-P72-013
Timing Belt - 14400-P72-014
Timing Belt tensioner - 14510-P30-003
Timing Belt tensioner spring - 14516-PR4-A00
ACL Engine Bearings B18C
or
Honda bearings (need to measure and order)
ARP Rod Bolts
ARP Headstuds
Old Jan 2, 2007 | 05:43 PM
vtec.dc2's Avatar
if you getting forged pistons, get forged rods as well
Old Jan 2, 2007 | 06:57 PM
OG undercover's Avatar
Old Jan 3, 2007 | 02:32 AM
jdm_DC2R's Avatar
Default Re: Looking for a breakdown of motor.. (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">if you getting forged pistons, get forged rods as well</TD></TR></TABLE>
Any recomendations for these? and what should i expect to pay give or take?
thanks for the great info guys
Old Jan 3, 2007 | 05:07 AM
andyt's Avatar
Default Re: Looking for a breakdown of motor.. (TheOnlyBrooklynITR)
Stupid question I guess, but in that pic above what valve cover is that?
I have one that looks like that, that someone gave me, but both my Rs say "Honda Motor Company" on the valve cover?
Old Jan 3, 2007 | 05:22 AM
exies's Avatar
Default Re: Looking for a breakdown of motor.. (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">Stupid question I guess, but in that pic above what valve cover is that?
I have one that looks like that, that someone gave me, but both my Rs say "Honda Motor Company" on the valve cover?</TD></TR></TABLE>
That's a JDM valve cover. Notice how the DOHC is small and VTEC is large. The USDM valve cover has it opposite. Also, as you have already noticed, the JDM just has the Honda logo whereas the USDM says Honda Motor Co.
Old Jan 3, 2007 | 05:56 AM
tartje's Avatar
Default Re: Looking for a breakdown of motor.. (exies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exies &raquo;</TD></TR><TR><TD CLASS="quote">
That's a JDM valve cover. Notice how the DOHC is small and VTEC is large. The USDM valve cover has it opposite. Also, as you have already noticed, the JDM just has the Honda logo whereas the USDM says Honda Motor Co.</TD></TR></TABLE>
every market but the US and Canada i think got that valve cover
Old Jan 3, 2007 | 06:00 AM
Pondus's Avatar
European valve covers are also like that, so it's not a JDM only thing.
Depends on your budget, but if you want a set of lightweight NA rods, Cunningham Ultralite, Crower Maxilight and Carillo Pro-A are all very nice lightweight rods. Expect to pay around $700 for a set. These will all be a good bit lighter than OEM, Carillo A-beam I believe is the lighest at 411gram, compared to ~520gram for a OEM rod.
Old Jan 3, 2007 | 06:05 AM
exies's Avatar
Default Re: Looking for a breakdown of motor.. (Pondus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tartje &raquo;</TD></TR><TR><TD CLASS="quote">
every market but the US and Canada i think got that valve cover </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">European valve covers are also like that, so it's not a JDM only thing.
I only mentioned USDM and JDM since those were to two I was sure of. I could only guess how the CDM and EDM covers looked and I didn't want to make assumptions.
Old Jan 3, 2007 | 06:07 AM
330R's Avatar
Default Re: Looking for a breakdown of motor.. (tartje)
That's correct, because in every other market the ITR was badged as a Honda.
Old Jan 3, 2007 | 02:39 PM
jdm_DC2R's Avatar
Default Re: Looking for a breakdown of motor.. (330R)
Well ive decided to go with the carrillo rods and m77 bearings along with the wiseco pistons. But looking at the part # for the carrillo rods...theres a couple options for the b18c motor:
AA-VTC&lt;A-55433
AA-VTC&gt;-65433S
AA-VTC&gt;-65433H
can anybody tell me the difference between these, and which one should i get ordered?
Old Jan 4, 2007 | 06:11 PM
jdm_DC2R's Avatar
Somebody must know something about this, i need this info asap from people that have experience with these parts before.
Old Jan 4, 2007 | 06:23 PM
BABY NSX's Avatar
I used part number: AA-VTC&lt;A-55433H
in my build
Old Jan 5, 2007 | 02:30 AM
jdm_DC2R's Avatar
Default Re: Looking for a breakdown of motor.. (BABY NSX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BABY NSX &raquo;</TD></TR><TR><TD CLASS="quote">I used part number: AA-VTC&lt;A-55433H
in my build </TD></TR></TABLE>
Thanks Doug!
Old Jan 5, 2007 | 11:32 AM
vtec.dc2's Avatar
unless you're building the motor yourself, consult with engine builder on whats best and needed for this build
Old Jan 5, 2007 | 12:01 PM
TPB's Avatar
TPB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">unless you're building the motor yourself, consult with engine builder on whats best and needed for this build</TD></TR></TABLE>
Agreed! If you're looking for a great engine builder, go see Gord Bush Performance in Toronto. He is an incredibly meticulous motor builder - money well spent.
Old Jan 5, 2007 | 01:32 PM
jdm_DC2R's Avatar
i have a good local builder here doing all my work. But just for my knowledge, doesnt all the parts have to be balanced before install, or something like that, or once everything is installed with crankshaft too. i can ask my builder but id rather get the info from u guys first and then see what he says too.
Old Jan 5, 2007 | 03:44 PM
TPB's Avatar
TPB
Default Re: (jdm_DC2R)
A good builder will answer all your questions to your satisfaction. Not discount some members' knowledge of rebuilds, but reputable engine builders are experts and will tell you everything you need to know, in advance.
Good luck with the build!
Old Jan 5, 2007 | 05:15 PM
92TypeR's Avatar
FSAE
Default Re: (TPB)
The only item that needs to be balanced is the crank, and really only if you are getting work done on it. Since you are not using OE rods or pistons, most aftermarket manufacturers will only sell sets that are within a certain range of eachother.
If you are using your stock crank, you can get the bearing info off your block for the main bearings. Since you are using aftermarket rods, you will need to use plastigauge and check the clearances on your rods, or use ACL's which are one size fit all.
Old Jan 6, 2007 | 05:54 AM
jdm_DC2R's Avatar
thanks for the info guys!
ill keep this updated and hopefully get some pics whenever i can of the process.
Old Jan 14, 2007 | 11:35 PM
ExospeedAMcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">Well ive decided to go with the carrillo rods and m77 bearings along with the wiseco pistons. But looking at the part # for the carrillo rods...theres a couple options for the b18c motor:
AA-VTC&lt;A-55433
AA-VTC&gt;-65433S
AA-VTC&gt;-65433H
can anybody tell me the difference between these, and which one should i get ordered?</TD></TR></TABLE>
Carrillo Rods has 3 options for rod choices.
We're a Carrillo Rod authorized dealer and we get this misinformation all the time. Most people dont know that there are several choices to pick from.
Pro-A all motor lightweight application with 5/16 WMC rod bolts
Pro-SA medium duty with 3/8 WMC bolts
Pro-H heavy duty with 3/8 WMC bolts(for setups not planning to take apart motor often)
Pro-H heavy duty with 3/8 CARR bolts(best rod bolts in the business, minimal rod stretch, can take apart rod bolts/caps and can reuse many times)
any other questions feel free to PM me.
Old Jan 15, 2007 | 04:38 PM
jdm_DC2R's Avatar
Default Re: Looking for a breakdown of motor.. (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">
thanks for the great info! your reply should help me out alot more now, alot clearer thats for sure. Ill shoot u a PM if i come up with any other questions
drivfastr
Nov 19, 2003 09:39 PM
Jon Black
Mar 10, 2003 07:11 AM
InfamousRS
Dec 15, 2001 09:22 AM
paulzy
Jul 16, 2001 08:35 AM
