squeaking
Old Jan 2, 2007 | 05:16 PM
v8Buster's Avatar
Default squeaking
squeaking when i turn the steering wheel left and right, only can be heard from inside the car. sounds like it is coming from the left side not sure.
Old Jan 2, 2007 | 06:51 PM
driftdas2000's Avatar
Default Re: squeaking (v8Buster)
Maybe its a ball joint does it squeek when pushing the car up and down. Hondas/Acuras ussually have the lower ball joint grease separate and dry cuasing a high pitched squeek. If it happens when turning its not the shock(doesnt move). Try dissasembling and exercise the ball joint around and reassemble also do the other and see if the grease moved around re lubes the joints. If its gone and comes back a while you may need to replace them. Make sure they arent loose though while checking them out. Another common problem is the rubber bushing drying out between the cradle and steering shaft.
Old Jan 2, 2007 | 07:15 PM
GTSR5SEJ's Avatar
check your tie rods too they will do the same as balljoints. hell they basically are ball joints just serve a different purpose. also check the rubber boot where the steering collumn comes through the fire wall. is it scrubbing the steering collumn?
Old Jan 2, 2007 | 08:15 PM
integrawow's Avatar
Check all bushings!
Old Jan 2, 2007 | 09:16 PM
low91rex's Avatar
Default Re: (integrawow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integrawow &raquo;</TD></TR><TR><TD CLASS="quote">Check all bushings!</TD></TR></TABLE>
$amGD3
Suspension & Brakes
Jun 27, 2011 10:20 AM
Drop_A_Dookie
12
Feb 13, 2011 07:56 PM
hondazccivic
19
Oct 16, 2008 08:20 PM
rachonda
Jul 5, 2007 06:54 PM
higgunscrx
Dec 19, 2006 11:13 AM
