hooking up an electronic speed sensor to a cable tranny
Old May 13, 2002 | 08:18 PM
rice4life's Avatar
Default hooking up an electronic speed sensor to a cable tranny
I have a Y1 cable tranny that uses a mechanical spedometer. I'm hooking up an Apexi avc-r boost controller and i need to connect it to and electronic speed sensor for the gear function. I can get the sensor from the junk yard but how do i hook it up. any one has wire diagram. i will be monitoring speed with the avc-r.
Old May 13, 2002 | 08:42 PM
StorminMatt's Avatar
Default Re: hooking up an electronic speed sensor to a cable tranny (rice4life)
I would look into the possibility of using the output of your in dash VSS rather that trying to use an electronic VSS on the transmission. The in-dash VSS works fine for a 1992-1995 ECU. So it should work fine in other applications that use an electronic VSS.
Old May 13, 2002 | 09:13 PM
rice4life's Avatar
Default Re: hooking up an electronic speed sensor to a cable tranny (StorminMatt)
i dont know what VSS stand for. but i use a pr3 ecu with my b16a swap. i dont think it has a speed sensor wire because it uses a cable for the speedo.
Old May 14, 2002 | 07:24 PM
The PR3 DOES have a CSS wire. It goes to the VSS, which is in the instrument cluster itself.
hypeRhatch
Sep 15, 2013 10:33 AM
hoga113
Mar 8, 2013 04:32 PM
kim_2_da_chee
11
Oct 8, 2003 09:02 AM
rice4life
May 14, 2002 05:45 PM
rice4life
May 14, 2002 08:30 AM
