Garrett turbo with 70 miles is SHOT!
So i purchased a t3/t04e 57 trim, .63ar turbo from vsracing.net, and viren is a great guy btw, but i just got to installing my turbo, and i noticed a problem right away. The car doesn't make any boost and just makes a loud woooooooooo sound. It reminds me of a whale or some ****. I took the turbo off and noticed the compressor wheel didn't want to move, it was pretty much stuck. If i turned it really hard it would spin, but then it would catch. I took off the compressor housing and noticed the wheel was shot. It looks as if though the wheel was hitting the compressor housing and rounded off all of the fins.
I thought it was something on my part with not tightening down the bolts after clocking the turbo, but all of them were torqued down. I don't know what happened and i truly think this is a manufacturer defect and not my fault. What can i do about getting a new turbo or getting this one rebuilt? I sent a pm to Viren at vsracing but i have no response yet.
$550 down the drain
$550 down the drain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">There has GOT to be some kind of warranty on that..</TD></TR></TABLE>
I sure hope so...i can't really afford another 600 dollar turbo..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch »</TD></TR><TR><TD CLASS="quote">sounds like a oil problem, seized the turbo</TD></TR></TABLE>
just got your pm now i ll contact you in the morning to send it in for warranty so they can take a look at definitely sounds more of oiling issue than anything else.
You should have waited to hear back from Viren. Take your feed line off. Make sure there is nothing clogging it. What size lines were you running?
I'm pretty positive it is getting oil, i just barely loosened the feed line and oil began pouring out. I installed another turbo that my friend had laying around so i can drive my car, and it is still working fine after 2 days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AaronJ »</TD></TR><TR><TD CLASS="quote">I'm pretty positive it is getting oil, i just barely loosened the feed line and oil began pouring out. I installed another turbo that my friend had laying around so i can drive my car, and it is still working fine after 2 days</TD></TR></TABLE>
did you prime your car to get oil pumping into it, before you started the car?
From: What Business is it of yours where Im from Friendo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing »</TD></TR><TR><TD CLASS="quote">any pics? it does sound like the bearings seized up</TD></TR></TABLE>
Yea pick would definately be nice.
Was it almost like a loud whining sound ? I remember we had a customer with a knock off turbo, basically the fins were running against the housing. I know its a knock of turbo, but just something to think about.
eg crunkmonster
Aug 17, 2006 09:26 AM
