Head gasket and timing belt question
Old Jan 2, 2007 | 04:31 PM
boostedek9's Avatar
Default Head gasket and timing belt question
Ok so yeah, I'm in the process of building my engine...I've heard misc things about how oem head gaskets are better than cometic...and I'm looking for anywhere between 450-500 on high boost...so I was wondering what you guys have had experience with when it comes to timing belts and head gaskets, what do you recommend?
Old Jan 2, 2007 | 06:56 PM
mike93eh2's Avatar
oem and oem.
Old Jan 2, 2007 | 07:10 PM
Topdawgg's Avatar
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">oem and oem.</TD></TR></TABLE>
Old Jan 2, 2007 | 08:25 PM
boostedek9's Avatar
OEM and OEM as opposed to like toda and cometic?...hm, I just cant see how oem will hold up to 450-500 hp, not to mention I like the flexibility of being able to lower/raise compression with cometics head gaskets....Simply because I'm runnin 9.0:1 compression and I kinda wanted to bump it up a little
Old Jan 2, 2007 | 08:33 PM
Runnerdown's Avatar
No reason to get anything else.
Old Jan 2, 2007 | 08:55 PM
boostedek9's Avatar
Thanks for the input guys, its much appreciated
Old Jan 4, 2007 | 07:19 PM
spoolingb20's Avatar
Default Re: (boostedek9)
This is a common question that you will see in all of the car forums. I would just suggest that you use a MLS gasket. I didnt think the OEM honda gaskets were MLS but I could be mistaken. I know the cometic gaskets are MLS and I currently have them on both of my cars with no sealing issues. The biggest thing with MLS gaskets sealing is making sure that both the block and head have unwarped and smooth surfaces.
Old Jan 4, 2007 | 07:23 PM
mike93eh2's Avatar
yea oem honda headgaskets are multi-layer steel.
Old Jan 4, 2007 | 10:58 PM
boostedek9's Avatar
So has anyone had problems with Cometic gaskets leaking or blowing?....and are all the big hp hondas running cometic or OEM? :D
Old Jan 4, 2007 | 11:42 PM
zexxbo's Avatar
if its daily driven and youre gonna be pushing it often, id reccommend the greddy timing belt. but yea, oem headgasket with copper spray.
Old Jan 5, 2007 | 04:04 AM
Synapse Motorsport's Avatar
Default Re: (zeimbo)
Oem and Oem
Old Jan 5, 2007 | 09:21 AM
underpressure02's Avatar
Default Re: Head gasket and timing belt question (boostedek9)
In all seriousness I was running autozone headgaskets this past year. Never had a problem with them.
Old Jan 5, 2007 | 04:30 PM
boostedek9's Avatar
eh I heard real bad stuff about greddy belts...I heard they love to skip teeth and snap
Old Jan 5, 2007 | 07:55 PM
zexxbo's Avatar
my friend has one on his 750whp gsr hatch, hasnt had a problem with it in the past 8 monthes he's had it on
Old Jan 6, 2007 | 07:49 AM
Topdawgg's Avatar
greddy timing belt is a waste of money IMO
Old Jan 6, 2007 | 10:36 AM
orange99si's Avatar
I used a cometic low comp. head gasket , and it now leaks after about 2 months. I am going back to OEM.
Old Jan 7, 2007 | 09:07 PM
boostedek9's Avatar
Hm, see I planned on using a high comp headgasket with a really low thickness to boost compression of my 9.0:1 slugs...idk, maybe its the thicker gaskets?
Krucial_Ek9
Jul 23, 2007 05:48 PM
mugencx
Jul 9, 2007 09:23 PM
invisible
Feb 3, 2007 01:20 PM
kantfadedisazn
Dec 20, 2006 05:08 AM
teal_deal
May 18, 2005 01:09 PM
