dizzy leaking oil.. help
Old Jan 2, 2007 | 10:02 AM
Ha Itz's Avatar
Default dizzy leaking oil.. help
i have had a oil leak for the past few days and i found out were it was from. i noticed i had oil all over my tranny and followed it and it lead to the dizzy.. there is alot of oil under the dizzy right belowe were it connects to the motor.. and there is also a little bit of oil leaking from the bottom of the dizzy cap.. is there a o ring or a gasket that needs to b between the dizzy and the motor cuz thats were its leaking from
Old Jan 2, 2007 | 12:07 PM
ridin98civic's Avatar
Default Re: dizzy leaking oil.. help (Ha Itz a Jew)
yup there is an o-ring between the dizzy and head. pretty common leak too.
Old Jan 2, 2007 | 12:15 PM
mike1114's Avatar
Default Re: dizzy leaking oil.. help (ridin98civic)
I replaced the O ring three times, even had a real mechanic do it the fourth time and it always leaks. I hate that fuking o ring.
I used honda bond on the flat surfaces of the block and dizzy when I installed the last o ring. I has never leaked now.
Old Jan 2, 2007 | 12:16 PM
Azn Kenny's Avatar
Maybe it's your cam seal then.
Old Jan 2, 2007 | 12:22 PM
BauleyCivic's Avatar
Risky Business
Default Re: (Azn Kenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azn Kenny &raquo;</TD></TR><TR><TD CLASS="quote">Maybe it's your cam seal then.</TD></TR></TABLE>
There's no cam seal on a SOHC.
For me, it ended up being the vtec solenoid gaskets. There are two of them. I'd replace the distributor o-ring, the valve cover gasket, and the vtec solenoid gaskets and that should fix the leak
Old Jan 2, 2007 | 12:24 PM
mike1114's Avatar
Default Re: (BauleyCivic)
for me, it was most likey gas *** vatozone o-rings.
the hondabond worked for me on the dizzy. Nothing leaks on my car now.
Old Jan 2, 2007 | 01:27 PM
Ha Itz's Avatar
Default Re: (mike1114)
yeah its off a obd2 ls in my civic ima try to replace the oring and see if that helps.. kan u explain more about the bond between the dizzy and the block.. wat part do i put it on?
Old Jan 2, 2007 | 01:50 PM
endlesswinterco's Avatar
Default Re: (Ha Itz a Jew)
i would just repalce the o ring without using anytype of bond. see how it goes then maybe seal it with a bond.
Old Jan 2, 2007 | 02:22 PM
Azn Kenny's Avatar
Doh, I didn't realize it was a SOHC...
Old Jan 2, 2007 | 05:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Azn Kenny &raquo;</TD></TR><TR><TD CLASS="quote">Doh, I didn't realize it was a SOHC...</TD></TR></TABLE>
actually he just said it was an LS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ha Itz a Jew &raquo;</TD></TR><TR><TD CLASS="quote">yeah its off a obd2 ls in my civic ima try to replace the oring and see if that helps.. kan u explain more about the bond between the dizzy and the block.. wat part do i put it on? </TD></TR></TABLE>
Tong.Y
Jul 4, 2011 08:16 PM
boost6ef9
Feb 10, 2008 11:10 AM
invisible
May 19, 2007 03:25 AM
thatbluecrx
Dec 9, 2004 03:06 PM
[ iLL ] iNt3GrA
Sep 2, 2004 02:19 AM
