Rear Mount question.
Old Jan 2, 2007 | 08:49 AM
1 sLoW hAtCh's Avatar
Default Rear Mount question.
Can anyone on here can tell me what's the easiest way to get the rear mount out w/o a hassle?
Old Jan 2, 2007 | 09:01 AM
MasterKwan's Avatar
Default Re: Rear Mount question. (1 sLoW hAtCh)
I took the tranny to crossmember bracket loose. it won't come out. Then I went through the top with a 2 ft extension for the 3 14 mm bolts into the crossmember.
Then you lift the bracket, pull out the old mount, put in the new one.
I will say this job is easy as hell on an EK/EJ and a total bitch on a teg and probably EG. There's a ton more room to work in the EK/EJ.
Old Jan 2, 2007 | 10:41 AM
EE_Chris's Avatar
Default Re: Rear Mount question. (MasterKwan)
In addition to the above (speaking from a DIY article and not experience), loosening the two side mounts (upper tranny and upper driverside) so that the engine can 'rotate' on the front two lower mounts, helps out too. The article also pictured a jack under the oil pan to 'rotate' the engine.
Old Jan 2, 2007 | 10:48 AM
mike1114's Avatar
Default Re: Rear Mount question. (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">In addition to the above (speaking from a DIY article and not experience), loosening the two side mounts (upper tranny and upper driverside) so that the engine can 'rotate' on the front two lower mounts, helps out too. The article also pictured a jack under the oil pan to 'rotate' the engine.</TD></TR></TABLE>
this will make is able to come out. You may have to rotate the "T" bracket some while taking it out. I changed out mine in my B series EG this way.
By jacking up the motor some, you get some room to wiggle the bracket out.
Old Jan 2, 2007 | 11:42 AM
MasterKwan's Avatar
Default Re: Rear Mount question. (mike1114)
If you use that technique, it might not be necessary to unbolt the bracket from the motor.
Old Jan 3, 2007 | 06:35 AM
yeah that's what i did too, i loosen the t-bracket and wiggle it around until i had room to pull out the rear mount, but i really hate crawling under the car, ahahaha jux thought there's other way that's all. Thanks a lot fellows.
Old Jan 3, 2007 | 07:20 AM
mike1114's Avatar
sometimes I think I spend more time under my car than in it.!!!!!
5genhatch
Feb 18, 2008 10:20 AM
code47mastermind
Dec 8, 2007 01:21 PM
crazyguy
10
Nov 27, 2007 05:34 PM
civiclxb16a
Apr 27, 2005 08:33 PM
Will Albers
Sep 30, 2002 08:03 AM
