Poor Mans Type R Is It Worth It??????
Old Jan 2, 2007 | 07:56 AM
blackjackEG's Avatar
Default Poor Mans Type R Is It Worth It??????
I have a GSR with a bent valve. A friend offered me a b16a head in trade for my gsr head so I could get my car running again. Is that gonna be more power or less power. I wanna eventually boost, so should I do it.
Old Jan 2, 2007 | 07:58 AM
eg6sir-s's Avatar
Default Re: Poor Mans Type R Is It Worth It?????? (blackjackEG)
keep your gsr head and have it ported and upgrade your valvetrain
Old Jan 2, 2007 | 09:01 AM
jay_cue's Avatar
Default Re: Poor Mans Type R Is It Worth It?????? (JJSpecTuning)
if you're not going to change out your pistons, your compression will drop. b16 head on gsr block would be good if you change out your pistons to either b16 pistons, or itr/ctr pistons.
Old Jan 2, 2007 | 09:39 AM
EJgsr's Avatar
Default Re: Poor Mans Type R Is It Worth It?????? (whal3_p3nis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whal3_p3nis &raquo;</TD></TR><TR><TD CLASS="quote">if you're not going to change out your pistons, your compression will drop. b16 head on gsr block would be good if you change out your pistons to either b16 pistons, or itr/ctr pistons.</TD></TR></TABLE>
very well said.
Old Jan 2, 2007 | 10:20 AM
bubblelsvtec07's Avatar
Default Re: Poor Mans Type R Is It Worth It?????? (USDMej1)
hey i have a qestion i wanna know what should i be running with this setup..
94 CIVIC HATCH CX
ls vtec
b18b bottom end
b16 pistons
type r flywheel
01 type r trans w/lsd
spoon headers
gsr head
dual springs/retainers
type r cams
skunk 2 intake
skunk 2 camgears
aem fuel rail
fuel pressure regulator
stock throttle ls
msd 2 step setup
P28 SKUNK 2 CHIP 9500REV 5500 VTEC
MY COMPRESSTION IS 11.58 AROUND THERE i wanna get it tuned before i run but i want an idea from people who know about this set up
Old Jan 2, 2007 | 10:26 AM
EJgsr's Avatar
Default Re: Poor Mans Type R Is It Worth It?????? (bubblelsvtec07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubblelsvtec07 &raquo;</TD></TR><TR><TD CLASS="quote">hey i have a qestion i wanna know what should i be running with this setup..
94 CIVIC HATCH CX
ls vtec
b18b bottom end
b16 pistons
type r flywheel
spoon headers
gsr head
type r cams
skunk 2 intake
skunk 2 camgears
aem fuel rail
stock throttle ls
msd 2 step setup
MY COMPRESSTION IS 11.58 AROUND THERE i wanna get it tuned before i run but i want an idea from people who know about this set up</TD></TR></TABLE>
hahaha you need do do a little more research....
Old Jan 2, 2007 | 10:34 AM
Earthworm Jim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackjackEG &raquo;</TD></TR><TR><TD CLASS="quote">I have a GSR with a bent valve. A friend offered me a b16a head in trade for my gsr head so I could get my car running again. Is that gonna be more power or less power. I wanna eventually boost, so should I do it.</TD></TR></TABLE>
Fix the GSR and leave the B16A where is it. A "poor man" that does the "poor mans type r" normally spends around the same amount of money as he would had he just bought a type r...
Old Jan 2, 2007 | 10:36 AM
Default Re: Poor Mans Type R Is It Worth It?????? (Earthworm Jim)
umm ok i guess u have no idea?
Old Jan 2, 2007 | 12:14 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubblelsvtec07 &raquo;</TD></TR><TR><TD CLASS="quote">umm ok i guess u have no idea?</TD></TR></TABLE>
you will run a 15.3 exact
Old Jan 2, 2007 | 06:48 PM
Default Re: Poor Mans Type R Is It Worth It?????? (doood)
which will make more power when i change the pistons to ITR and boost it?
Old Jan 2, 2007 | 06:51 PM
mighty_sol's Avatar
if you're going to go boost then i'd just fix the GSR with upgraded stuff and then while you're in there prepare the block for boost....i know it's more expensive but if you're going to do it anyway might as well do it since everything you need to change/ mod is right there in front of you and easy to get at...not to mention you can save some money by not buying a new set of gaskets again when you go boost. good luck
Old Jan 2, 2007 | 08:19 PM
Targa250R's Avatar
be professional
Assuming you have a B18C1 or B18C with a P72 head (and not a B17A1 with a PR3 head), you're actually going to lose power with the PR3 head unless you re-use the B18C cams and install higher compression pistons (or alternately mill the head, use a thinner head gasket, etc.).
Old Jan 2, 2007 | 08:35 PM
mugenEGG's Avatar
i say keep the gsr...
Old Jan 2, 2007 | 09:21 PM
nello a.'s Avatar
fix what you got
Old Jan 2, 2007 | 09:36 PM
spenny's Avatar
Default Re: (nello a.)
bent valve = get new valves.
broken is always a great excuse to upgrade
Old Jan 2, 2007 | 09:51 PM
Default Re: (spenny)
I have ITR pistons to use, but i am gonna look into getting cams. Any idea of what kind of power would be made????
Old Jan 2, 2007 | 09:53 PM
boostaddict14's Avatar
Default Re: (blackjackEG)
i like poor mans type r, but id personally just do the valvetrain on the gsr head
Old Jan 2, 2007 | 10:59 PM
eklum's Avatar
94 CIVIC HATCH CX
ls vtec
b18b bottom end
b16 pistons
type r flywheel
spoon headers
gsr head
type r cams
skunk 2 intake
skunk 2 camgears
aem fuel rail
stock throttle ls
msd 2 step setup
get rid of one of your header's and im sure you'll run around 13.4-14.0
Old Jan 2, 2007 | 11:03 PM
rodrez.'s Avatar
You can get a number of opinions from people telling you to do one thing or the other, but you need to look at:
-what you're going to use the car for
-how much money you're willing to spend now as well as later
-what your ultimate goal is
before you make a decision, or start trading away parts you may want to keep in the long run.
Old Jan 3, 2007 | 05:31 AM
Default Re: Poor Mans Type R Is It Worth It?????? (rodrez.)
EKLAM THANKS FOR YOUR HELP... qestion the headers are no good??
Old Jan 3, 2007 | 07:09 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bubblelsvtec07 &raquo;</TD></TR><TR><TD CLASS="quote">EKLAM THANKS FOR YOUR HELP... qestion the headers are no good??</TD></TR></TABLE>
Why do you need more than one of them?
I can tell you right now that the ECU chip is garbage. Spend the money on custom tuning with Crome.
EG6Boy702
Apr 23, 2009 11:10 AM
smithb299
Mar 21, 2009 04:33 PM
hott95ej2
Sep 25, 2005 10:35 AM
7rrivera7
Sep 17, 2003 09:58 AM
:jdmshmaydm:
Jan 2, 2003 06:32 PM
