Anyone turbo a d series motor???
Old Jan 1, 2007 | 09:02 PM
Cheefed's Avatar
Default Anyone turbo a d series motor???
i was thinking about doing a really cheap turbo set up on my weak *** d15 to get a little extra power. just wondering if anyone has ever turboed a d15 and what the results were. would it be worth it? i was thinking that i could make around an extra 40-50 hp....
Old Jan 1, 2007 | 09:19 PM
e jay one's Avatar
Default Re: Anyone turbo a d series motor??? (Cheefed)
are you talking about d15b2 dpfi garbage? im sure it can be done but in the end its not gona be worht it cause there is only 2 injectors that cant deliever enough fuel required for the boost.
Old Jan 1, 2007 | 09:31 PM
STREETWERKZ's Avatar
Default Re: Anyone turbo a d series motor??? (e jay one)
this has actually been covered before too. recently.
i say just do it. those motors are free.
Old Jan 2, 2007 | 06:09 AM
Loserkidwac's Avatar
Default Re: Anyone turbo a d series motor??? (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">this has actually been covered before too. recently.
i say just do it. those motors are free. </TD></TR></TABLE>
Do it, you will benifit from an MPFI swap, you can make an HMT kit for probably $500 or less and easily make some decent power...I believe hose bottom ends have really weak rods so if you want it to last spend some money on fuel management, get a 90-91 pm6 when you go MPFI and chip it and have someone tune when you go boost...I say HF mani w;' adapter plate and slap a T25 or a 14b on it and grab a side mount IC from a junkyard some DSM 390 should be plenty or the 450s would be even better for a little more $, some PVC pipe for IC pipping or some rando Junkyard IC piping off some turbo cars...definately make a decent set-up
Old Jan 2, 2007 | 08:00 AM
ryan89crx's Avatar
http://www.homemadeturbo.com
Old Jan 2, 2007 | 10:03 AM
dohc_profile's Avatar
boost the B2! if u roll with dpfi..ur rollin DEEP
Old Jan 2, 2007 | 03:48 PM
Cheefed's Avatar
Default turbo
how much you think it would be to change over to mpfi? yeah i found a cheap forged manifold on ebay for around $120. thinking about a saab 9000 as the turbo donor car, would the saab's turbo be good to use?
cheefed
Old Jan 2, 2007 | 05:17 PM
AJxr's Avatar
Default Re: turbo (Cheefed)
that turbo will be perfect, i ran the same on my d15b7, spools pretty quick and pulls good. d15 turbo is fun.
but yeah definately go mpfi, should cost less then $100 if you look in the right places.
Old Jan 2, 2007 | 05:24 PM
661rex89si's Avatar
mpfi conversion and either a t25 from a 2g eclipse or a 14b from a 1g eclipse. either or should be cheap.
Old Jan 2, 2007 | 06:00 PM
boosted crx-r's Avatar
Default Re: (661rex89si)
save your money and buy a real motor
Old Jan 2, 2007 | 06:06 PM
Got_soy's Avatar
Default Re: (boosted crx-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted crx-r &raquo;</TD></TR><TR><TD CLASS="quote">save your money and buy a real motor </TD></TR></TABLE>
Like what a B16?
Boost it. PERIOD. you can do **** for real cheap. and if you feel like steping up to a d16, alot can change over.
Old Jan 2, 2007 | 06:25 PM
SiR99's Avatar
boost it, blow it, and buy another D-series or a b18a.
Old Jan 2, 2007 | 07:01 PM
pendejon's Avatar
i think you should get a vtec head for it, along with a p28, and you can make some sick power stock bottom end.
check this out
http://www.hondamarketplace.co...52477
i made 210whp with a d15b (jdm 1.5 vtec) when the turbo had the baby compressor wheel on it at 9psi. bone stock bottom end!!
check it out, maybe we can work a deal
Old Jan 2, 2007 | 07:05 PM
Default Re: (pendejon)
HF mani with adapter should cost you around $90, saab turbo is perfect...mpfi shouldn't cost to much around $100 maybe a little more...I have a D16a6 intake mani if you are interested, not looking fo rmuch since its just collecting dust right now
Old Jan 2, 2007 | 07:14 PM
Tippyman's Avatar
Default Re: (ryan89crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan89crx &raquo;</TD></TR><TR><TD CLASS="quote">http://www.homemadeturbo.com
Lot's of people have done super cheap turbo setups on those motors.
So long as you get some sort of fuel management and don't boost very much, you should be just fine.
With a DPFI though, I don't know what kinda fuel management is available. FMU's suck, but it might be your only option if it's a low buck build.
Old Jan 2, 2007 | 07:18 PM
Got_soy's Avatar
Default Re: (Tippyman)
there has been a couple of dpfi builds.
Old Jan 2, 2007 | 08:35 PM
IP RACING's Avatar
Default Re: (Got_soy)
I have a a6 intake manifold.. sell it real cheap like $40 or whatever.. its just gonna be sitting in my garage I got a new motor
Old Jan 3, 2007 | 12:13 AM
Cheefed's Avatar
Default Re: (IP RACING)
yeah, well if i had the money and time i would wanna swap a b16a1 into my civic, but you know how things go, i was more looking to do the swap in 2007s summer. oh, and the cats offering their intake manifolds, im interested and down if its cheap. post more info!!!!!
Old Jan 3, 2007 | 12:20 AM
Cheefed's Avatar
Default Re: (Cheefed)
oh..., and ill give all the info with some pics once i start the project, i probaly should get a new head though, would a d16 headfit on my d15b2 bottom end????
Old Jan 3, 2007 | 03:17 AM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheefed &raquo;</TD></TR><TR><TD CLASS="quote">oh..., and ill give all the info with some pics once i start the project, i probaly should get a new head though, would a d16 headfit on my d15b2 bottom end????</TD></TR></TABLE>
Yes sir! Search for mini me.
There's a couple good threads in the faq. I would recccommend a D16A6 head, so you don't have to worry about VTEC and converting to OBD1 and all that crap.
Old Jan 3, 2007 | 08:37 PM
BlueRex1020's Avatar
the d15b2 n d16a6 heads r the same...the only difference is the cam in the a6 is a little better...
ap1$2k
Mar 9, 2007 10:03 AM
turnsignalandy
14
Apr 3, 2006 05:32 AM
god.loves.ugly
15
Apr 19, 2005 08:33 AM
Hybrid96EK
Jan 27, 2005 07:34 AM
99exd16y8
34
Oct 28, 2004 05:12 PM
