How hard is it to change the headlight switch on a 90 crx si???
Old Jan 1, 2007 | 07:47 PM
94b16teg's Avatar
Default How hard is it to change the headlight switch on a 90 crx si???
I just bought a crx for $300 but the headlight switch and blinker deal is broke do I have to pull the steering wheel???? Cause im sure thats not fun! Any help would be great thanks justin.
Old Jan 1, 2007 | 07:52 PM
silentdork818's Avatar
Default Re: How hard is it to change the headlight switch on a 90 crx si??? (94b16teg)
Pull the steering wheel, undo steering column cover, unscrew and unplug the switch, the rest is reverse of removal. Taking off the steering wheel isnt bad at all, its just the little H emblem and a 19mm nut then just wiggle it off.
Old Jan 1, 2007 | 08:42 PM
89efDUSTY's Avatar
Default Re: How hard is it to change the headlight switch on a 90 crx si??? (silentdork818)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdork818 &raquo;</TD></TR><TR><TD CLASS="quote">Pull the steering wheel, undo steering column cover, unscrew and unplug the switch, the rest is reverse of removal. Taking off the steering wheel isnt bad at all, its just the little H emblem and a 19mm nut then just wiggle it off. </TD></TR></TABLE> true one of the easiet things to do...
Old Jan 1, 2007 | 08:47 PM
dr_latino999's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94b16teg &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a crx for $300 but the headlight switch and blinker deal is broke do I have to pull the steering wheel???? Cause im sure thats not fun! Any help would be great thanks justin.</TD></TR></TABLE> I can do mine in about 10 minutes, a little bit more if I still had the H on the steering wheel. I actually have a spare Column switch assembly F/S.
Old Jan 2, 2007 | 05:50 AM
94b16teg's Avatar
Default Re: How hard is it to change the headlight switch on a 90 crx si??? (dr_latino999)
How much????
tfarol
17
Nov 14, 2008 02:48 PM
ek9tl
Jan 31, 2007 09:00 PM
dustin_crxsi
Oct 30, 2006 05:29 PM
accordredliner
Feb 19, 2006 12:26 AM
hondatuner20
Jan 17, 2006 01:37 PM
