06 fogs
Old Jan 1, 2007 | 07:40 PM
mrnewguy's Avatar
* B A N N E D *
Default 06 fogs
I currently have the 2006 replica's fogs and Im concerning about the wires going through the firewall, I cant seems to find the hole for it.... tried I also downloaded the 06 fogs installation guide.... still not getting it... Any idea? I have a 2006 rsx base 5spd with the yellow ebay replica fogs... so I just need which hole to put my wires through then ill get the rest. Thanks
Old Jan 1, 2007 | 11:17 PM
pat.ter.rick's Avatar
Default Re: 06 fogs (mrnewguy)
you don't put it through the firewall. it comes with two wire harness. on is for the foglight itself and you just connect it to the wires within the engine bay. then theres the switch the harness for the switch. you remove the center console, the steering wheel cover and the bottom panel of the steering wheel. then you should lower the fuse box and you gotta connect wires to it.. then route the wires to the center console and connect them. and you gotta connect one of the plugs on top of the steering wheel near the turn signal thing. but the Foglight installation instruction should be very clear that you do not put the wires through the firewall.
Old Jan 2, 2007 | 10:35 AM
mrnewguy's Avatar
* B A N N E D *
Thank you
Old Jan 2, 2007 | 06:23 PM
Rice-aronie's Avatar
Default Re: (mrnewguy)
The stock plug in the engine bay will not work for the ebay fog lights. Well for most of the ebay fogs that I have seen anyways. That plug near the driver side headlight was made for the oem fog lights. If you have the ebay fogs that most people have then you will most likely have to run it through the grommet under the driver side fender. There is a black plug there with wires running through them already, that is where I ran mine. Just remove the fender liner/wheel well cover and you will see what I am talking about.
Old Jan 2, 2007 | 10:47 PM
Default Re: (Rice-aronie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rice-aronie &raquo;</TD></TR><TR><TD CLASS="quote">The stock plug in the engine bay will not work for the ebay fog lights. Well for most of the ebay fogs that I have seen anyways. That plug near the driver side headlight was made for the oem fog lights. If you have the ebay fogs that most people have then you will most likely have to run it through the grommet under the driver side fender. There is a black plug there with wires running through them already, that is where I ran mine. Just remove the fender liner/wheel well cover and you will see what I am talking about.</TD></TR></TABLE> serious? i thought it would fit...i guess it won't but iono... i got the OEM Fogs so i just plugged it in the plug in the engine bay by the driver side headlight.
Old Jan 3, 2007 | 01:29 PM
RICKYritethere's Avatar
Default Re: (pat.ter.rick)
my sisterf had this same problem! she has a 06 automatic tho...
Old Jan 3, 2007 | 07:20 PM
Default Re: (RICKYritethere)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RICKYritethere &raquo;</TD></TR><TR><TD CLASS="quote">my sisterf had this same problem! she has a 06 automatic tho... </TD></TR></TABLE>ebay fogs?
Old Jan 4, 2007 | 08:12 AM
mrnewguy's Avatar
* B A N N E D *
Ill try it this weekend with Rice-aronie method, thanks dude!
keslerbuilt
Jan 15, 2014 12:39 AM
EM24
Honda Civic (2001 - 2005)
Aug 11, 2009 02:49 PM
pyro13
Apr 2, 2009 08:40 AM
slonga
Jan 28, 2009 05:49 AM
forksports
Jan 4, 2002 12:09 AM
